Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-04-2010, 04:32 AM   #1
WPL
Cabinets split
Two years ago I had new doors put on my cabinets. The plywood is now split. And the doors are shagging. I have put glue in the splits and clamped them until dry. I have put wood matches in the crew holes. All to no a vale.
What can I do to fix this? The cabinets were built in 1962. I can't afford to replace them.
WPL is offline   Reply With Quote
Old 01-04-2010, 07:03 AM   #2
Cabinets split
What kind of glue did you use. TitebondII would be my choice. Inject the glue into the crack and clamp. Once dry, it may split somewhere else, but no the same spot. I suspect what started it was the hole was not predrilled.
Old 01-04-2010, 09:09 AM   #3
Cabinets split
On wood that thin, from the looks of the picture, even if you drilled it, it may have split. Maybe my eyes are deceiving me. What is the width of the door? Your best bet may be to move the hinge down and repair the old crack, then predrill the screw holes and re-attach. It could also be that the screw was driven too far into the plywood and after use it split. Not much to do. Any one else have an idea?
Daddyshammer is offline   Reply With Quote
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 08:54 PM
Tiles before or after kitchen cabinets? nipab Remodeling 5 08-29-2009 10:04 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General Discussion 14 07-21-2008 12:32 AM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 11:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
