Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-05-2008, 03:47 AM   #1
Cabinet water damage (pics)- any advice?
The side of our bathroom cabinet has had some water damage, which makes me really sad
We didn't notice what was happening (frequent baby water splashing) until too late... now I am hoping to figure out what can be done. In the images, you can see that there is sort of an arc of discoloration with a little warping at the bottom, then peeling in places. What does it take to repair such a situation? The warping and even the discoloration doesn't really bother us, mostly we need to fix the flaking that has occured.
Can the side panel be replaced easily (we don't know where the cabinet/wood is from) by itself? Or could it be sanded and re-finished? And can anyone tell me vaguely what this wood is ... please forgive the newbie question, but it isn't a solid chunk of wood right? something is flaking off of the cabinet, could that be a finish or glaze?
Or if it's really involved and requires taking apart a significant bit of the side of the cabinet, how much might it cost to have someone fix this (work + supplies)?
Part of me is just thinking of taking a matching paint to the side and covering up the spots, since they're actually quite small and this isn't a particularly visible part of the bathroom except for someone on the toilet :P.
nb... the photo in which the wood appears darker/chestnut is more accurate.
Asma is offline   Reply With Quote
Old 12-05-2008, 04:41 AM   #2
oo.. could the cabinets be veneered? http://www.keidel.com/design/select/...atl-veneer.htm
Old 12-05-2008, 09:19 AM   #3
A lot of cabinets nowadays are made of shelf paper covered particleboard or Masonite. This cannot be refinished in the traditional sense. You might find that baseboard molding or cove molding covers up the damaged area.
AllanJ is online now   Reply With Quote
Old 12-05-2008, 10:40 AM   #4
Visit your local home improvement store and pick up a piece of base mold, looks like your existing base mold is 3-1/4", but measure to make sure. Take a door off the cabinet and to the store with you to match up a quart of stain as close as possible. Cope the stained mold into the existing painted mold.
Jeeper1970 is offline   Reply With Quote
Old 12-05-2008, 10:47 AM   #5
Building codes guy, Mod
thekctermite's Avatar
Yeah, those are cheap-o cabinets and there isn't a way to truly repair it. Without replacing them (which wouldn't be all that expensive if it is just a vanity), you can do a number of things to cover up the problem. Paint, trim boards, etc.
You might be able to buy some time by applying some wood veneer with pressure sensitive adhesive (PSA). It is essentially a very thin wood sticker that you cut to fit the side of the cabinet using a sharp utility knife. Stain and polyurethane, and you've got a good band aid fix that is DIYer friendly. PSA veneer can be bought at woodworking stores, or online retailers like Rockler.com.
thekctermite is offline   Reply With Quote
Old 12-05-2008, 08:15 PM   #6
as long as we get to vote, here's mine, either let it go for now, or as said earlier, pickup a piece of matching trim and nail'er in.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
More On This Topic
The bathroom is a notorious place for germs to grow and thrive. It's also a typical haven for mold, mildew and fungus of all kinds. The damp atmosphere and general lack of proper air circulation in most bathrooms are major contributors to this sorry... Read More »
Small Bathroom Renovation
Small Bathroom Renovation by Expert Village
So this is our second bathroom, and this is the bathroom right off the master bedroom. In this bathroom, the main things we did with the home renovation are that we put in the shower, and I love the shower that it doesn’t have a shower curtain, so... Read More »
Remember to center the medicine cabinet in your new bathroom. Learn how to add a new bathroom to a home, including tips on setting a medicine cabinet in this free home improvement video. Read More »
Hello. My name is Grady Johnson and I'm a professional painter. Today I represent Expert Village.com. Now it's time to paint the base of the cabinets. Now today we've chosen to paint the base of the cabinets the same color as our walls and our ceiling... Read More »
Shellac is a natural resin produced by a insect which lives in trees, mainly in India. It has been used for centuries to finish wood by dissolving it in denatured alcohol and then painting on like other finishes. Shellac is natural and non-toxic and... Read More »
Low hot water pressure crebive Plumbing 26 01-10-2010 12:54 PM
Tankless or tank, but not both gp_wa Electrical 43 10-15-2008 11:08 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Sill plate damage from water. Do I need to replace? twilightcall Building & Construction 4 06-05-2008 08:55 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
