Cabinet Trim Gaps - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 01:56 PM   #16
Originally Posted by beerdog View Post
Gap closes tight in the spring and summer. At least it did last year.
Thats what truss uplift does
mrgins is offline   Reply With Quote
Old 11-11-2012, 09:29 AM   #17
So, my truss uplift got worse this year. Decided to do some research. Looks like me improving my attic intake ventilation this summer improved my ventillation but also increased the trust uplift. Basically, I had maximum ridge vent exhaust coupled with essentially no intake flow. Found a good short write-up explaining it and another example of how to hide it. Can't really "fix" it.
http://www.inspectionlibrary.com/truss.htm
http://www.renovation-headquarters.c...uss-uplift.htm
beerdog is offline   Reply With Quote
Old 11-13-2012, 08:28 PM   #18
gap at ceiling
run a screw up from inside the cabinet into the ceiling if you can find the framing or ceiling truss.... this is the best way to keep the cabinet from moving... especially if you have a soffit above the wall cabinets. I can't really tell from the pictures.
dgainey62 is offline   Reply With Quote
Old 11-20-2012, 06:51 AM   #19
if you screw the cabinet into the truss, the power of the up lift will pull on the weakest part, which may be the top rail of your cabinet. Better to install a moulding to the gap and attach it only to the truss so it can ride up and down without revealing the gap or damaging the cabinet
Filling gaps between door frames and trim after new sheetrock applied. Mike in Arkansas General DIY Discussions 6 05-25-2014 07:52 AM
Installing under cabinet lighting trim? kcrossley2 Kitchen & Bath Remodeling 5 11-13-2012 08:38 PM
How to trim gaps in stairway white/woodgrain? FreedomSearcher Flooring 22 01-05-2011 03:24 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
