Cabinet For Stand Alone Oven - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 03:47 AM   #1
Rewards Points: 16
Cabinet for stand alone oven
I have just purchased an oven that is about 30" wide, 20"deep and 22" high. I would like to build a cabinet to mount my gas burners (cooking stove) in the top of the cabinet and then put the oven under the stove.
The top of the oven gets hot to the touch, uncomfortably hot. I am concerned about putting the oven into an enclosed area made of wood. I was thinking of doing the following things to mitigate/eliminate fire hazard:
1. Covering the interior of the oven shelf with (what I call) fireproof sheetrock.
2. Installing a fan or two in the rear to draw heat out of the area so that the temp does not build up.
What are your thoughts/suggestions?
pengyou is offline   Reply With Quote
Old 01-06-2011, 07:24 AM   #2
Gas or electric oven?? Gas ovens usually vent somewhere at the top, which is likely what you feel. I doubt that is it hot enough to start a fire, but it could damage things like formica, etc. You probably need an alternate means to vent the oven to the outside.
Old 01-07-2011, 11:41 PM   #3
Cabinet maker
Augie Dog's Avatar
Just follow the manufacturer's recommendations.
Single wall ovens are built to go in a cabinet and most of the time under a cook top. Space can get real tight if you mix manufacturers.
Augie Dog is offline   Reply With Quote
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-03-2011 12:09 AM
Tall oven cabinet jsteve846 Carpentry 4 08-12-2010 06:36 AM
Correct Material for Eye-level Oven Cabinet Bouraq Carpentry 4 02-05-2009 06:13 PM
Oven - junction box in cabinet DIYGST Electrical 5 11-13-2008 04:23 PM
