Cabinet Space Above Kitchen Stove. What's Normal? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 03:18 PM   #1
Rewards Points: 410
Cabinet space above kitchen stove. What's normal?
I have a '62 house, and included a CAD drawing of my kitchen stove area.
My wife and I want to put a microwave above the stove, but they're typically around 16" tall and if I put one of those in there it's going to hang below the bottom cabinets by 2" and leave only 14" of room between the microwave and stove. That doesn't seem like a lot of room, especially to use the back burners.
I think I have to shorten the cabinet above the stove so it's more than 30" above it. What distance is normal between the top of the stove, and the bottom of the cabinet above? Thanks
Piedmont is offline   Reply With Quote
Old 12-16-2011, 08:02 PM   #2
Rewards Points: 13,260
Anything above the stove needs to be at least 18". Bottom of a cabinet, bottom of microwave, whatever.
Old 12-17-2011, 03:20 PM   #3
On the instructions for the microwave, it will also show the manufacturer's required minimum. I believe they are required to give you that info.
oldhouseguy is offline   Reply With Quote
Old 12-17-2011, 04:13 PM   #4
Rewards Points: 558
take a look at this site: http://www.ehow.com/how_10052341_ins...wave-oven.html
epson is offline   Reply With Quote
Old 12-18-2011, 08:15 AM   #5
Stove clearance
Your clearance may be OK if you have a stove with front controls, but to match local code and allow your fan to vent properly, you might want to tweak the cabinets. I have only 15.5" clearance but front controls. It works fine but new cabinets are in the making.
FYI in my neighborhood adding the microwave also required a dedicated circuit upgrade, but I left the old wire in the wall for a future receptacle when I redo the cabinets.
Chemist1961 is offline   Reply With Quote
Painting grooves in kitchen cabinet doors. jcraw84263 Painting 5 11-10-2011 01:05 PM
Kitchen cabinet conundrum allbymyself Kitchen & Bath Remodeling 18 01-25-2011 12:11 AM
outlet in kitchen cabinet timchi29 Electrical 2 01-03-2011 09:25 PM
kitchen cabinet mircrowave range marin001 Building & Construction 1 12-10-2010 06:32 PM
Kitchen Cabinet PROBLEM! zetti1102 Painting 6 09-17-2009 09:09 PM
