Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-09-2010, 08:59 PM   #1
Cabinet Repair
I have a cabinet that is pulling away from the wall. Here is a picture:
There is a gap between the wall and the cabinet. It appears the cause of this is because the floor is not level and the the cabinet is leaning forward. How can I fix this? I am thinking of using shims to raise of the front of the cabinet. I want to make sure this is a proper fix though.
Here is another picture of the entire unit:
Thanks in advance for the help.
Willie5566 is offline   Reply With Quote
Old 03-09-2010, 09:09 PM   #2
Super Moderator
Cabinet Repair
The shims are standard practice.----The cabinet should have been screwed to the wall,also.
Lift off the top and you will see a strip of wood on the back of the cabinet--Run a couple of 2' or 2 1/2 " screws through that strip-into a stud. On a narrow cabinet you might not find more than one stud to hit-studs are usually 16 inches apart.
Good luck--have fun--Mike--
oh'mike is online now   Reply With Quote
Old 03-09-2010, 09:23 PM   #3
Cabinet Repair
Is it hard to lift of the "top?" I assume you are referring to counter top.
Old 03-09-2010, 10:47 PM   #4
Moderator
Termite's Avatar
Cabinet Repair
No need to remove the top in most cases. You should be able to shoot screws through the back of the cabinet carcasse by opening the door. You'll probably need to remove the toe kick board in order to shim under the front of the carcasse, then replace it after the shims are installed.
Install the screws AFTER shimming...Don't try to draw the cabinet back to the wall with the screws.
As far as screws, you should be able to get cabinet installation screws at a home center. They have a washer-type head. Deck screws would work, but not as well. I prefer to use 2-1/2" Kreg pocket hole screws (Lowes sells them in the tools department) because they have a small washer head, self-drilling threads, they're fairly aggressive and they're square drive so you won't strip them out driving them in.
Old 03-09-2010, 11:20 PM   #5
jlhaslip's Avatar
Cabinet Repair
Cabinets don't just decide to lean forward like that.
Is your floor moving? Can you access the level below the cabinet to have a look? Post pictures.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 03-10-2010, 10:08 AM   #6
Cabinet Repair
Agreed. I do not think it is a floor issue. The owner before bought the house as a flip and it looks like he cut some corners in certain places. That said the house is about 85 years old so there are issues with shifting.
Old 03-10-2010, 10:09 AM   #7
Cabinet Repair
I assume the toe kick board is the board on the front of the cabinet near the floor. Am I correct? Is it hard to remove?
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Kraft Cabinet - how do i repair white covering Mr Chips Remodeling 2 01-14-2010 11:45 AM
Repair Kitchen Cabinet Door navymom1km Carpentry 2 12-17-2009 07:08 AM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 11:08 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 11:59 PM
