Cabinet Handles Before Finishing? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-31-2009, 10:43 AM   #1
cabinet handles before finishing?
should i drill all my holes for my handles before staining and finishing my cabinets?
rustic is offline   Reply With Quote
Old 03-31-2009, 10:55 AM   #2
Registered User
Termite's Avatar
It makes absolutely no difference.
I probably would, simply because I could mark light pencil layout lines on the wood for the hole locations and then sand them off after drilling. But, you can do the same thing on a layer of masking tape over the finished cabinets.
Old 03-31-2009, 12:22 PM   #3
thank you
Old 03-31-2009, 03:08 PM   #4
Rewards Points: 5,336
If you use a template and a backer board when you drill the holes, you will be fine. The backer board is clamped behind the door/drawer so the bit doesn't, "blow out" the wood fibers when it comes out the back.
Ron
Old 03-31-2009, 03:58 PM   #5
ok, very good tip, thanks
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 11:59 PM
