-   -   cabinet handles before finishing? (http://www.diychatroom.com/f14/cabinet-handles-before-finishing-41493/)
rustic 03-31-2009 10:43 AM
should i drill all my holes for my handles before staining and finishing my cabinets?
Termite 03-31-2009 10:55 AM
It makes absolutely no difference.
I probably would, simply because I could mark light pencil layout lines on the wood for the hole locations and then sand them off after drilling. But, you can do the same thing on a layer of masking tape over the finished cabinets.
rustic 03-31-2009 12:22 PM
thank you
Ron6519 03-31-2009 03:08 PM
If you use a template and a backer board when you drill the holes, you will be fine. The backer board is clamped behind the door/drawer so the bit doesn't, "blow out" the wood fibers when it comes out the back.
Ron
rustic 03-31-2009 03:58 PM
ok, very good tip, thanks
