Cabinet Door. - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-26-2014, 11:36 AM   #1
Cabinet door.
Morning folks. I going to build a simple hanging cabinet out of Mdf in my garage. The dimensions will be 20 inch wide x 12 inch deep x 36 tall. I'm not not going to make a face frame unless absolutely necessary. Anyhow Im wanting to know how to make a door to fit. I will be using 3/4 in melamine for the door. Again I'm not trying to fancy, I just want to cut it down to size and then mount it. I just didn't exactly know what size it needed to be and how to layout my brackets. Thanks In advance
shaydu is offline   Reply With Quote
Old 01-26-2014, 11:41 AM   #2
DIY staff
Rewards Points: 7,174
If you are using European cup style hinges--just make the doors as wide as the outside dimensions of the box---use frameless style hinges---
Old 01-26-2014, 12:18 PM   #3
lol didn't realize it was that simple. Thanks!!
Old 01-26-2014, 12:37 PM   #4
K&B Designer
Live_Oak's Avatar
Just be careful using MDF as your box. You don't use the same type of fastening with that as you do plywood. Use Spax or Kreg screws meant for the job, not a standard wood screw, or a (shudder) drywall screw. And if you do shelves in it, do them in a dadoe, not a butt joint.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 01-26-2014, 02:25 PM   #5
Thanks live oak. I was initially going you use the kreg jig for everything. I don't have table saw so I can't cut dados. What is the issue with doing butt joints on Mdf?
Old 01-26-2014, 04:36 PM   #6
K&B Designer
Live_Oak's Avatar
The issue is the weight bearing capacity. And that issue is across materials. Its a butt joint issue, not a materials issue. You are relying on the strength of the fasteners alone to bear the weight in a butt joint. Of course, if you are only going to use the cabinet to house a quart of oil and a can of spray paint, your plan may be sufficient. In my experience though, garage storage alwayss ends up being too small and overloaded. Bigger is always better. More weight bearing capacity is always better. And slightly over engineered is almost good enough. :-)
The Following User Says Thank You to Live_Oak For This Useful Post:
oh'mike (01-26-2014)
Old 01-26-2014, 04:48 PM   #7
Rewards Points: 12,882
You would be way better using 3/4" plywood not MDF.
MDF does not hold screws well and will soak up moisture like a sponge.
Old 01-26-2014, 06:38 PM   #8
Gotcha. I had a bunch of scrap material laying around from another project that I was trying to get rid of. I reckon I will scrap that idea. Thanks for the input!!!
Old 01-30-2014, 08:05 PM   #9
Professional
TotalHomeworx's Avatar
Using a kreg jig and some glue to build it will be more then strong enough. If you are concerned about moister, just paint it.
TotalHomeworx is offline   Reply With Quote
Old 01-31-2014, 11:04 AM   #10
Rewards Points: 808
I was gonna say, doors? It is a garage right?
IslandGuy is offline   Reply With Quote
Old 02-02-2014, 01:33 PM   #11
Thanks. Yeah I want to add a door to it. It may be unnecessary but I think it woulda me it look better. Plus I would like to know how to do it for future projects.
Old 02-02-2014, 11:13 PM   #12
Rewards Points: 3,719
Even for a garage I would think twice before using the MDF.
They aren't going to be perfect dados but you can cut them with a router in several passes if you use guides.
Colbyt is offline   Reply With Quote
hinges on flush-face cabinet doors vs. old door hinges denemante Kitchen & Bath Remodeling 1 08-05-2012 06:47 AM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
cabinet door glass Master Brian Carpentry 6 03-23-2012 09:55 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Cabinet Door Hinges Eric_ht Carpentry 6 11-24-2007 10:13 AM
