Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-19-2008, 05:33 PM   #1
Default Cabinet Crown Molding and Hood Range?
Hi guys I have a question, i'm installing some crown molding at the top of my kitchen cabinets but ran into a problem. The hood range is at the same level as the top of my cabinets. I tried stopping the Crown at the Hood Range but unfortunately the crown "cap piece" goes to far into the Hood range. I then tried to put the "cap piece" right next to the hood range but this now pushes my molding further out exposing the cabinet. I went ahead and ran straight temporarily but would like to find out if anybody has any ideas on how to cut this so it looks good. Any help is greatly appreciated. Pictures posted below
cabinet-crown-molding-hood-range-picture-010.jpg   cabinet-crown-molding-hood-range-picture-009.jpg
gate1way2 is offline   Reply With Quote
Old 09-19-2008, 06:22 PM   #2
Building codes guy, Mod
thekctermite's Avatar
That's a challenge. So the hood stands a little proud of the face of the sheetrock?
The only thing I can think of is to slightly overlap the hood, and do a 90* mitered (outside corner) return into the front face of the hood. It would have to overlap the hood just a couple inches. You would cut the miter and glue the small return piece on the longer piece of crown before nailing any of it up. Once assembled you can use a sharp chisel or jigsaw to remove a little material from the bottom part of the crown where it gets pushed out by the hood...That way it mates tight to the cabinet.
thekctermite is offline   Reply With Quote
Old 10-16-2008, 12:59 AM   #3
do u have a cabinet designing software
jameschacko is offline   Reply With Quote
Old 10-16-2008, 01:13 AM   #4
Why??
More On This Topic
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an inside corner. Crown molding sits against the wall usually at a 38 degree or a 45 degree that depend on the type of... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
Hi, I'm Ed Reyes from Master Builders here in Tampa, Florida. I am here for Expert Village and I am going to show you how to use the proper use for a plunge router. There are many uses for this tool. Depending on the type of router bit you use which... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip we are going to demonstrate how to cut an inline joint with a miter saw in crown molding. You might think that cutting your corners at the compound miter setting that you would... Read More »
On behalf of ExpertVillage.com we're going to talk to you a little bit today about how to check your fluids under your hood. First of all you look on all the caps, they'll have little descriptions of what they are, this is for window wash right here so... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
