Cabinet Backsides - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 07:13 AM   #1
cabinet backsides
I'm creating an office area using individual cabinets. The design results in the backside of two cabinets being exposed. I have the material necessary to cover them but want some installation advice. For example, should I use filler material to increase the glueing area on the vertical edges of the cabinets? Should I put filler in the center of the cabinet area to increase stability?
scratch007 is offline   Reply With Quote
Old 06-08-2010, 08:01 PM   #2
Depends on what the filler material is going to be!
Is to be 3/8" plywood or 1/8" pressed particle board. Or whatever?
Old 06-09-2010, 10:00 AM   #3
The material to be used to cover the exposed backside is 1/8" hardboard, stained to match the cabinets.
Old 06-09-2010, 03:16 PM   #4
The hardboard won't be very stiff, so I would place a couple of stringers in there to support the middle.
Old 06-09-2010, 03:24 PM   #5
tks - sounds like the safest approach.
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
Drawer Slide for Cabinet w/o back george0410 Carpentry 2 04-08-2010 05:53 PM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 10:08 PM
Under cabinet Light Suggestions jamiedolan Electrical 7 04-01-2009 11:59 AM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 10:59 PM
