Buying A Saw - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 09:21 PM   #1
gruntman's Avatar
Rewards Points: 79
Buying a saw
I have a house that needs carpentry work and I'd like to try doing some of it myself. I have used rip saws and they do the job but I have noticed the mitre saws and bench saws in the box stores and was wondering if they might be a better way to go. Whats the "best bang for the buck" for someone just starting to learn but doesnt want junk?
gruntman is offline   Reply With Quote
Old 06-18-2009, 09:25 PM   #2
I have a ridgid skil saw, works great - new blades when needed are key
I also bought a plunge mitre saw - dewalt I think
Makes trim work a breeze & I built a picnic table w/angled cuts easily
What are you going to be doing?
Trim work - mitre saw
Bench saw - cutting trim work thinner to fit - anything that needs a straight edge cut
Old 06-18-2009, 09:33 PM   #3
I don't know. I have about 8 different saws myself. I would say probably a table saw. You can rip, cross cut, miter cut, rabbit, and dado with it. You probably only need a small portable like the Bosch or Ridgid.
hayewe farm is offline   Reply With Quote
Old 06-19-2009, 09:00 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
If you are just starting a home shop, I'd suggest a table saw as the most basic need and probably the most useful followed by a miter saw. I have heard good things about the Ridgid table saw. If you can swing it, I would go with this:
http://www.ridgid.com/Tools/TS3660-T...w/EN/index.htm
Old 06-19-2009, 10:39 AM   #5
gruntman's Avatar
Rewards Points: 79
I think Im only going to be using it to cut molding or trim, or for building shelves. BUt that willl probably change once I start doing stuff. Someone wrote me and said that a "sliding compound mitre" would do the trick. Scuba - what's a "plunge" mitre.
Rigid, Dewalt, Makita - how do you choose?
Old 06-19-2009, 02:09 PM   #6
Don't qoute me on that
I know some used to just slide back & forth
The blade did not raise up
But it appears most of them now raise up
So they "plunge down" to cut
I bought the 12" model - bigger the better
Electric brake - blade slows down faster
Dust collector - less dust
Rigid & Dewalt are what I usually stick with
But I have a Makita jig saw, & a grinder - maybe something else
Old 06-19-2009, 02:21 PM   #7
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Yea, a miter saw is pretty handy for the things you mention. I have a Makita
http://astore.amazon.com/handyguys-20/detail/B0000789HL
There is a pretty decent price I think at our Amazon affiliate store.
Brik is offline   Reply With Quote
Old 06-19-2009, 06:33 PM   #8
I have a DeWalt DW716 12" with laser but they are a little pricey for some.
Buying a Sawzall Mulligan Tools 47 12-06-2011 01:01 AM
buying a house with structural damage?? saholly_8 Building & Construction 2 02-02-2009 12:29 PM
Help buying exterior doors hellothere123 Building & Construction 8 10-21-2008 07:30 PM
Buying a problem? srtbrew General DIY Discussions 1 09-13-2008 12:06 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 11:17 AM
