Buying An Interior Slab Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 03:42 PM   #1
Landlord
Rewards Points: 89
Buying an interior slab door
Any tricks for lining up the new door with hinge cutouts on the frame? Basically the new door is drilled for the knob but not the hinges. Thanks
cocean is offline   Reply With Quote
Old 11-05-2010, 04:44 PM   #2
jschaben
Rewards Points: 502
I assume the door frame is already mortised for the hinges. Measure down from the top of the doorframe to the hinge mortise on the frame. Subtract an eigth of an inch and mortise the door. That should give you the proper gap at the top. Make sure the door length is OK accounting for carpeting, etc. Trimming hollow core doors is another bad dream if you need to do that. Last one I did, there was less than half inch/edge for sizing.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 11-05-2010, 04:46 PM   #3
Unhappy
3-4 ways
do you have the old door slab?
know right now you might have a problem (problems just = more work) with the location of the hole for the door knob matching new to what you have at the keeper area of the jamb.
slow down and be sure of top and bottom of slabs.
1. remove hardware from old slab / place old slab on top of new slab. ( check to see if 2 1/8 knob holes line up).
if holes line up and door edges are all the same... easy ...take speed square and transfer location of hinge locations to new slab.
Mortise /install old or new hinges./ hang new slab..you may need to pack hinges for minor adjustments.
You may have needed to trim some sides & or bottom of new slab ( all depends on the opening.) and the old keeper area does not match up.
adjust as needed.. filler and paint as needed..
2. No old slab? check opening for plumb / square measure the heck out of everything. hang the new slab... tune up as needed.
3. is a combination of 1&2
4. + / are the other ideas that get posted ( you can always post problems you can't head scratch away)... or hire a handyman / carpenter, lots of them looking for work these days
Big Bob is offline   Reply With Quote
Old 11-05-2010, 07:03 PM   #4
Rewards Points: 5,336
The new slab is rarely if ever cut at all and never lines up with the lock or hinges. You buy a door with nothing cut out. You use the old door to set up the hinge mortises. After you cut those and actually hang the door on them, that's when you cut the hole for the lock.
This assumes the frame is square and you don't need to machine a rhombic shape to fit the opening.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Big Bob (11-05-2010)
Old 11-05-2010, 07:59 PM   #5
well said
Ron 6519, Well said, with an economy of words.
My wife says I tend to be verbose among other things.
Purchasing a new slab without any cuts or holes is the way it should be done.
Old 11-05-2010, 09:19 PM   #6
jschaben
Rewards Points: 502
Ron
Hi Ron - that also assumes the old door is available to transfer the mortises from. Many old houses have had the doors removed and, worse yet the opening is 75-76" high. Door widths generally come in 2" increments but, unless special ordered, are 80" tall.
John Schaben
Old 11-05-2010, 09:38 PM   #7
Renovations contractor
Bonzai's Avatar
Or alternatively buy a prehung door and replace the door and frame ... Appreciate this is not always an easy option but sometimes it can be less work over all and you don't have the lining up issue.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 11-06-2010, 03:29 PM   #8
There are a number of possibilites with this post. When the poster provides enough information, we can provide specific suggestions.
Ron
Old 11-06-2010, 08:16 PM   #9
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Take the old door off. Put it on Craigslist.
Fit the new door slab into the opening using shims and wedges to get a perfect reveal on both sides, top & bottom.
This may mean setting it into the opening, marking where it needs to be trimmed, removing it, cutting it and re-shimming.
This may seem like extra work but this will insure that you don't set the hinges, hang the new, square door in an old, out-of-square opening and then realize it should have gone up or down to make a good fit.
Once you have the perfect fit, just mark the slab because you'll see the old mortises in the jamb.
tcleve4911 is offline   Reply With Quote
Moving interior door to garage - awkward? violetUK Building & Construction 3 12-05-2009 09:40 AM
Storm Door Handle Installation jogan General DIY Discussions 3 06-09-2009 09:57 PM
Purchasing and buying door/ Low ceiliengs mjkpainting Carpentry 4 11-21-2008 06:53 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
