BUTCHERBLOCK HELP! Don't Want To Screw This Up... - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 08:27 PM   #1
BUTCHERBLOCK HELP! Don't want to screw this up...
Ok here is the deal. I bought two craftsman butcherblock tables tops (2'x6') and wanted to glue them together for one awesome 4'x6' table top.
I trimmed just a little of 1 of the long edges of each top, and glued and clamped them together.
Problem is, there is a "slight" variance (tinny lift) in one spot and some tiny gaps in others. (mostly due to the table tops themselves not being 100% flat).
So, I know I can put a little wood filler in, then sand and then apply something but ... how do I do this without jacking up the finish. Really I just want that 1 seem to look good. I don't want to re-do the whole new top.
1) What sand paper grit should I use.
2) What finish should I apply? (Mineral oil/beeswax? other?)
THANKS SO MUCH!
kronic24601 is offline   Reply With Quote
Old 03-19-2011, 07:23 AM   #2
Rewards Points: 5,336
You should have jointed the edges before you glued them together. There's not much you're going to do after the fact other then a filler which will not be a good visual.
Cut them apart and joint the edges. Put them together in a dry fit to check for issues. Correct the issues before you glue them together.
If, after the glue up, one side is slightly above the other, sand it flush.
When you're happy with the connection, then you finish the surface.
Rushing the process only leads to redoing it.
Ron
Old 03-19-2011, 08:35 AM   #3
Rewards Points: 121
What Ron said.
If you didn't know to do this first then we can assume you are not a woodworker, nobodies perfect .
If you want it to look right then both joined edges need to be perfect, and matching. Call a couple of local cabinet shops and see what they would charge. It will be worth it. There are ways to take some of the thick edge off and add a mechanical way to pull it tight, without losing any of the strength of the joint. They should be able to help.
Post your location and someone may be able to recommend a place.
JoeLena is offline   Reply With Quote
Old 03-19-2011, 08:49 AM   #4
DIY staff
Rewards Points: 7,174
Post a picture if you can---it sounds like you glued end grain to end grain----that is the weakest of all wood joints---post a picture and suggestions will come.---Mike---
Old 03-19-2011, 01:01 PM   #5
Hi Guys,
Thanks for your help. Here is a photo, the split looks a lot larger here than it is ... each of the wood sectionals is 2.25" thick. Oh and yes, to those that already saw the obvious. I'm a total noob. Gotta learn somehow right? (I should mention, there is no "seam" on the ends ... i'ts only in the middle a bit.)
Old 03-19-2011, 01:14 PM   #6
the Musigician
DangerMouse's Avatar
Have you flipped the pieces around? Sometimes a gap on one side will be flat and flush flipped to the other side.
At least around here. Po)
DM
Old 03-19-2011, 01:28 PM   #7
I did try that, but it was worse. I got these two tops for $80 a piece ... obviously craftsman isn't trying as hard as they used to ...
In any case ... I'm to lazy to saw them apart and try again... knowing me I'd just make it worse. I think I'll try this
  1. Apply wood filler (let dry)
  2. Use WET #400 Sandpaper with Mineral Oil to Sand
  3. Then ... um ... beeswax and hope for the best?
I figure if this doesn't work, I can always cut it off later. My question is this.
1) #400 isn't likely to take off any "edges" should I start with a 220? ... or is this a horrible idea and I should use #600 or higher?
2) is this a horrible idea in general?
Old 03-19-2011, 01:52 PM   #8
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
Did you use any dowels or biscuits when you put the two pieces together? If not with a gap like that it will be a weak point in the table top and possible break apart at some point. It would be worth the effort to just cut it along the joint. You will only loose the saw blade width in material. Then if you don't have a jointer, take it to the local High School and I bet they would be happy to joint it and dowel or biscuit the joint and glue it for you. They may even be willing to cut it back apart for you.
Filling it and sanding will only hide it but it will be a weak joint.
Sanding: I would not use wet sandpaper. Do it all dry, start with 60 or 80 grit get the majority of the material at the joint sanded down being careful not to take to much off. Then move to 100 or 120 grit, then 220, and then if you want do a final with 440. With each sanding be sure to sand the entire surface to keep it even and uniform. Alway sand with the grain, if you don't the sanding marks will show when you put a finish on.
danrb007 is offline   Reply With Quote
Old 03-19-2011, 02:14 PM   #9
hmm ... ok ... this is just showing me how stupid I was to start this before posting here.
1) No I did not use any dowels or biscuits ... doh!
2) Jointer ... damn ... that would have been a good idea as well.
well ... I guess I'd better contact some Wood shops in the area I live in the San Fernando Valley of CA (Los Angeles County).
On a side note. As far as the week joint goes. If this table top is sitting on top of another plywood top, will the week joint matter? Or will it still eventually split more along that line over time? (I really am a newby).
Old 03-19-2011, 02:17 PM   #10
the Musigician
Are they solid? What type of wood and how thick?
I know what I'D do...
DM
Old 03-19-2011, 06:02 PM   #11
You don't want to use filler on that. It will not look good. If you do any type of finish on it it will liekly show like a sore thumb. Just cut it apart witha circular saw. No need to be accurate. If you can haul it as is just have the shop that jointers it cut it apart. they will liekly have a large table saw and it will take them no more than 5 minutes. Biscuits will help keep the top surfaces even.
beerdog is offline   Reply With Quote
Old 03-19-2011, 07:04 PM   #12
Experienced
Jackofall1's Avatar
What are the other (2) surfaces like? can you cut apart, turn each piece 180*, then drill dowels and join. Just a thought as the original surfaces should already be straight.
Mark
Old 03-20-2011, 11:21 AM   #13
Jack of all trades
danrb007's Avatar
It may not, but how would you feel if after you get it all finished and looking nice it comes apart. Then you have to start all over again. Why not do it right before you get it all done.
Old 03-20-2011, 12:20 PM   #14
Mark
The doweling procees takes a lot more experience then either a router and a spline or a bisquit connection.
Ron
Old 03-20-2011, 12:55 PM   #15
Rewards Points: 558
If the doweling or bisquit joining is too hard for him maybe he should looking into getting a kreg jig which is much more user friendly just a thought…
epson is offline   Reply With Quote
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 02:56 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 08:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 03:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
gas line vs screw wobblybowl Plumbing 5 05-27-2009 11:49 PM
