Built-In Shelving - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-26-2009, 09:03 PM   #1
Built-In Shelving
Is there a good place online where you can buy shelves that are similar to the nice thick shelving that you see when you look at houses that have the built-in shelving?
Built-in shelves that come with houses always seem to look alot nicer than the ones you see at target, or Lowes.
Is there special places to buy these? Or is there a different name for them?
limitdiy is offline   Reply With Quote
Old 12-26-2009, 09:18 PM   #2
MSG
I did my built-in shelfs and I got the meterial from home depot.
MSG is offline   Reply With Quote
Old 12-26-2009, 09:22 PM   #3
Did you use the stock shelves they have? or did you custom order them?
Old 12-27-2009, 12:41 AM   #4
MSG
I took a full sheet of MDF and cut it myself. and added the arbrite on top.
Old 12-27-2009, 12:52 AM   #5
Rewards Points: 1,016
Here's a thread I started awhile back regarding a problem I encountered when building mine - folks then asked about the construction, so I added several pictures and info. Maybe it can provide you some ideas.
Entainment center - ceiling differs 1.25" inches side to side - what to do?
Old 12-27-2009, 06:16 PM   #6
What is MDF and what is arbrite?
Old 12-27-2009, 08:05 PM   #7
In all likelihood the shelves you see are just standard 3/4 inch material with a front edge applied that extends somewhat below the bottom of the shelf to give it the appearance of being thicker. That is normally how it's done.
Mike in Arkansas is offline   Reply With Quote
Seeking garage cabinets shelving plans/help Robert131 Building & Construction 3 08-18-2011 08:23 PM
LCD Mount and built in cabinet - Need Advice/Ideas Lynch Building & Construction 8 11-07-2009 10:56 PM
Installing built in dishwasher... manofmany Electrical 2 07-20-2009 03:34 PM
built under oven as a built in one? helen30 General DIY Discussions 3 01-27-2008 04:15 PM
