-   -   Built-In Shelving (http://www.diychatroom.com/f14/built-shelving-60344/)
limitdiy 12-26-2009 09:03 PM
Built-In Shelving
Is there a good place online where you can buy shelves that are similar to the nice thick shelving that you see when you look at houses that have the built-in shelving?
Built-in shelves that come with houses always seem to look alot nicer than the ones you see at target, or Lowes.
Is there special places to buy these? Or is there a different name for them?
MSG 12-26-2009 09:18 PM
I did my built-in shelfs and I got the meterial from home depot.
limitdiy 12-26-2009 09:22 PM
Did you use the stock shelves they have? or did you custom order them?
MSG 12-27-2009 12:41 AM
I took a full sheet of MDF and cut it myself. and added the arbrite on top.
vsheetz 12-27-2009 12:52 AM
Here's a thread I started awhile back regarding a problem I encountered when building mine - folks then asked about the construction, so I added several pictures and info. Maybe it can provide you some ideas.
http://www.diychatroom.com/f15/entai...what-do-44001/
limitdiy 12-27-2009 06:16 PM
What is MDF and what is arbrite?
Mike in Arkansas 12-27-2009 08:05 PM
In all likelihood the shelves you see are just standard 3/4 inch material with a front edge applied that extends somewhat below the bottom of the shelf to give it the appearance of being thicker. That is normally how it's done.
