Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-01-2012, 03:48 PM   #1
TDO
Built in shelves
I posted this in drywall area, but it may fit better here.
we're adding built in shelves/entertainment center in our basement. 9 compartments total, with 3 rows and 3 columns, will go pretty much from floor to ceiling, 9' ceiling. Middle compartment will house my tv. Eventually it will be mounted, but for a while we'll just use the stand and set it on the shelf.
Here is my question: can I use 3/4" plywood for the the shelf bottoms and cover with drywall for a smooth look or should I just use finish grade plywood for the shelves without drywall, and paint them same color as walls with latex paint?
And if I use wooden shelves alone what do you use to get that smooth finish between the drywall and the shelf?
TDO is offline   Reply With Quote
Old 09-01-2012, 11:54 PM   #2
Built in shelves
build your shelf out of wood. To get a clean finish in all of the areas where the shelf and the wall come together you should use your skills.
HartKyle83 is offline   Reply With Quote
Joining corner wall shelves Pierson Paint Carpentry 10 12-24-2011 04:10 PM
DVD shelves above wainscoating? Morgan19 Home Theater 1 10-08-2011 10:40 AM
Pantry Sliding Shelves nicksteel Carpentry 14 05-23-2011 06:07 PM
Building White Shelves limitdiy Carpentry 9 12-28-2010 03:43 PM
Cantilever shelves in bathroom pennshaq Remodeling 1 07-11-2010 09:26 PM
