Building A Workbench. Need Plans - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 08:48 PM   #16
Rewards Points: 590
Originally Posted by Cintron12
well
Thanks for your post.
What is this? 2nd she or he posted this here.
nikeman is offline   Reply With Quote
Old 06-22-2012, 08:53 PM   #17
Rewards Points: 590
Any tips on vice location on table?
Old 06-22-2012, 09:06 PM   #18
Depends on what you're using the vise for and where the bench is in relation to the rest of the work space. I have a vise mounted to my bench on the front edge, left side. It's on the front edge because the vise hangs down past the ledge, and I wasn't interested in building up a platform for it (if I built a platform I could mount it further back to center it to work more over the center of bench). It's on the left-hand side because, A) I'm right handed, and, B) the right side of the bench is up against the wall; so mounting it left-side is more comfortable & convenient for me and in relation to my work space. Hope this somehow helps you decide...
pucks101 is offline   Reply With Quote
Old 07-02-2012, 01:15 PM   #19
hboogz's Avatar
Rewards Points: 97
Nikeman -- do you plan on covering the tabletop with a protective film or tin laminate? That tabletop is 3/4 shelf grade plywood screwed down at each of the posts ? Looking to building something similar but need my tabletop to be able to come off easy enough since my space is tight...
hboogz is offline   Reply With Quote
Old 07-02-2012, 08:06 PM   #20
Rewards Points: 590
I am going to leave it as is for now since I won't use it to much. If it starts to get beat up I will put a protective layer over it. I was think a thin sheet of sheet metal or something. Yes it is 3/4" presanded plywood. For some reason home depot had seemingly identical sheets but one was $10 or more cheaper. I even had them cut it for me which made my life easier.
I put probably more screws than I needed on mine since I do not plan on taking it down. I have seen plans online for collapsible benches that actually looked pretty easy to build. That might be a good route for you to take. Some looked like they would fold up against the wall.
Old 07-14-2012, 03:14 PM   #21
Joe Average
Rewards Points: 28
My two cents for the top is a solid core door. I picked a used one up from Habitat for Humanity for about $65. Trimmed it a tad and now have a very solid worksurface.
qualls6 is offline   Reply With Quote
Need help with building a workbench top with glued 4x4s blue sky Carpentry 11 01-14-2012 12:08 PM
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 02:09 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Building a Workbench - Is this design strong enough? stubits Carpentry 3 03-12-2010 08:57 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
