Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-09-2012, 03:54 PM   #1
Building a workbench. Need plans
Want to build a workbench in my shed with the scrap wood I have laying around. I want a bench that looks good and is solid. My dimensions to make it fit nicely where I want it are as follows.
92.5" Long
35.5" tall (without plywood top)
28" deep
I want to be able to store bulky heavy stuff under this thing also. I have found some that I like online but I can't find the one I wanted to build a while back! Any tips for building a clean looking workbench? Anyone know of any good plans online?
nikeman is offline   Reply With Quote
Old 06-09-2012, 05:11 PM   #2
GBrackins's Avatar
check these out .... http://www.woodmagazine.com/woodwork...ts/work-bench/
of course I don't know what type of bench (wood working, metal working, etc.) you're looking for, or the typical of scrap you have. But there are some nice ones in there.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 06-09-2012, 09:22 PM   #3
dpach's Avatar
Although I have no official plans since it was home built, here's the one I built for my garage. 2x4 framing put together with lag bolts, with 3/4 inch MDF shelft and a double 3/4 inch MDF (so 1 1/2 inch thick) top which is covered with tin.
It's now 6 years old and holding up like the day it was built.
dpach is offline   Reply With Quote
The Following 2 Users Say Thank You to dpach For This Useful Post:
gma2rjc (08-09-2012), goosebarry (06-11-2012)
Old 06-09-2012, 09:30 PM   #4
How deep is yours from front to back? Why did you use such a thick top? I'm just planning to use 1/2" presanded plywood and in the future if it gets all beat up I'll cover it with diamond plate or something.
Old 06-10-2012, 03:05 AM   #5
JOATMON
ddawg16's Avatar
Don't even consider anything less than 3/4" for the top. 1/2" Is going to be too thin.
I used 3/4" Melamine to most of my work bench and cabinets. On the work bench, I have a sub-frame of 2x4's....the actual top is 2x6's on their side with 3/4" plywood on top of that....as soon as I finish up some other major projects (like my house), I am going to toss on a layer of 1/4" plate steel and then cover that with a sheet of 14g stainless steel.
Not real obvious from this pic, but the bench does not touch the floor. It is all attached to the wall. This lets me wash the floor and not worry about getting them wet. It's basically a whole lot easier to clean.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 06-10-2012, 02:05 PM   #6
dpach's Avatar
It's 28 inches deep which allows for things like bench top drill presses, etc to sit on it with room. I went 1 1/2 inches thick because there are times where I have heavy items such as snowmobile engines. I covered it with thicker galvanized tin so oil, etc could be wiped off and not soak in to the wood. Plus, its very smooth and easy to sweep up dust, dirt, etc.
I'm not sure I would use diamond plate since it has raised ridges which won't allow things to sit evenly or flush and you don't want bench top tools wobbling. Plus the raised diamond checkers would make brushing the dirt, dust, etc off it more difficult.
But to each their own.
Old 06-11-2012, 02:09 PM   #7
I'll do a limited amount of wood working on it. I want to put miter saw on it and a vice clamp. I don't do a lot of wood working but when something comes up I always wish I had a nice workbench with room to work. My shed is 12' from front to back and I'm planning to make it a little under 8' long to leave space for a large tool box one day. All the plans you guys linked me to weren't free but they look simple enough to build. Keep pictures coming to give me more ideas.
Old 06-17-2012, 02:31 PM   #8
I'm in the process of building this work bench and I need a little help. What's the best way to attach this corner so I won't need a support beam back there?
I have the one by holding it in place and the other side is attached to a 4x4 as the support beam on that front corner. Ideas? I tried screwing in at an angle but it's not working out for me.
EDIT: Would a corner brace on the inside and one on the underside be strong enough? The back 2x4 has 2 screws in each stud going across 92.5"s.
Under Side
Inside:
Old 06-17-2012, 06:43 PM   #9
Never mind. All done
Old 06-17-2012, 10:16 PM   #10
I would do some type of a ledger board to support the backside
Looks good
Eds_tls is offline   Reply With Quote
Old 06-18-2012, 08:55 AM   #11
Looks good
There is a 2x4 going across the back that the top plywood lays on. I put 2 3" screws in each stud along that back wall. Isn't that a ledger board? I also put 2 2x4s across the bottom of the tabletop, one on each side of the center support.
Old 06-20-2012, 09:19 PM   #12
CrossWorks's Avatar
Lol...Nikeman, would you actually post a level that reads off by a bit! Show off!
Nice job anyway. Now if I stood on there...that would be the true test!
6'-4" 268lbs!
A great personality will open many doors in life,
but it's your character that keeps them open!
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 06-20-2012, 09:29 PM   #13
6'-4" 268lbs!
It would hold you no problem.
Old 06-20-2012, 10:12 PM   #14
6'-4" 268lbs!
He did that on purpose so it would drain spills properly
pucks101 is offline   Reply With Quote
Old 06-21-2012, 08:16 PM   #15
This may sound dumb but I got a vice clamp and I am not sure where on the table I'm supposed to mount it. I can't put it right on the corner since their is a 4x4 post there. Any suggestions?
Need help with building a workbench top with glued 4x4s blue sky Carpentry 11 01-14-2012 01:08 PM
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 03:09 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
Building a Workbench - Is this design strong enough? stubits Carpentry 3 03-12-2010 09:57 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
