Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-10-2012, 10:01 AM   #1
building wood ramps for curb
I need to craft up some ramps to roll some music equipment up a standard curb. Looking for an easy way to construct something so that things will roll up the curb and the ramp wont get kicked out- easier to make out of plywood- or 2x4's or both??
skinut2234 is offline   Reply With Quote
Old 10-10-2012, 10:08 AM   #2
A pressure treated 6 X 6 cut at a 45 deg. along it's length.
Buy a set of aluminum ramps made to roll a lawn mower up into the back of a pickup truck.
Old 10-10-2012, 10:35 AM   #3
Use pt 2x4's or 2x6's across for your decking over a frame is easy. This is pretty permanent though unless you have a place to store it. We have done this to get pianos, bass amps, etc. in and out of our basement on a much larger/permanent scale. On the level runs, we used 4X4 rails, build a slanted frame out of 2x4's for a ramp. You could build just the ramp part to get over the curb. It's held up amazingly well and conveniently removable if needed. We've had it 12 years now, only replaced 2 boards so far.
Complete directions: http://www.matadorcoupe.com/seebee65/Boardwalk.htm
Pianolady is offline   Reply With Quote
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 04:23 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 11:56 PM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General Discussion 0 05-22-2010 02:31 AM
Building house using wood from lot.... wilyum Building & Construction 4 06-29-2009 03:17 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
