-   -   building wood ramps for curb (http://www.diychatroom.com/f14/building-wood-ramps-curb-159624/)
skinut2234 10-10-2012 09:01 AM
I need to craft up some ramps to roll some music equipment up a standard curb. Looking for an easy way to construct something so that things will roll up the curb and the ramp wont get kicked out- easier to make out of plywood- or 2x4's or both??
joecaption 10-10-2012 09:08 AM
A pressure treated 6 X 6 cut at a 45 deg. along it's length.
Buy a set of aluminum ramps made to roll a lawn mower up into the back of a pickup truck.
Pianolady 10-10-2012 09:35 AM
Use pt 2x4's or 2x6's across for your decking over a frame is easy. This is pretty permanent though unless you have a place to store it. We have done this to get pianos, bass amps, etc. in and out of our basement on a much larger/permanent scale. On the level runs, we used 4X4 rails, build a slanted frame out of 2x4's for a ramp. You could build just the ramp part to get over the curb. It's held up amazingly well and conveniently removable if needed. We've had it 12 years now, only replaced 2 boards so far.
Complete directions: http://www.matadorcoupe.com/seebee65/Boardwalk.htm
http://www.matadorcoupe.com/seebee65/BoardwalkFix4.jpg
