Building Window Sills - HELP!!! - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 11:33 AM   #1
I have three windows that have large ledges that my builder was going to build window sills for. He was going to cut wood for the ledge part and then add a wood lip that he would attach to finish it off. Apparently, he was advised that he cannot use two piece construction because if water or moisture gets in between the joints, it would be ruined. I have attached pictures of the window sill and ledge and would really appreciate any suggestions of what I could do with this sill and ledge - open to new ideas. And I should mention that we are on a budget! Thank you!
By the way, is it an option to drywall the ledge or could it be more susceptible to water/moisture damage?
Building Window Sills - HELP!!!-window-ledge.jpg   Building Window Sills - HELP!!!-window-ledge2.jpg
lgallo is offline   Reply With Quote
Old 03-05-2010, 12:04 PM   #2
Love for Construction
<*(((><'s Avatar
The first thing I would question is why is the builder worried about water intrusion?
Did he put the window in? Because I'm pretty sure if I installed a window I would make it water tight, unless the homeowner leaves it open.
I would not have a problem at all installing wood trim like suggested (stool and apron) as I would have made sure water wouldn't be coming through a window that was flashed and installed properly.
Just my 2cents.
<*(((>< is offline   Reply With Quote
The Following 2 Users Say Thank You to <*(((>< For This Useful Post:
12penny (03-06-2010), Willie T (03-05-2010)
Old 03-05-2010, 12:11 PM   #3
Jay123's Avatar
What's going on with the first window pictured...doesn't look too well thought out (or the soffit on the right side of it), and after it's trimmed it will really look wanky.
Jay123 is offline   Reply With Quote
Old 03-05-2010, 12:15 PM   #4
<*(((><'s Avatar
I agree. I thought I would leave that one be.
Old 03-05-2010, 12:26 PM   #5
Old School
Willie T's Avatar
It is usually not a good idea to D/W ledges. Placing display items on the ledges eventually scrapes and scratches them.
Willie T
Old 03-05-2010, 01:06 PM   #6
Is there exposed concrete where the wood is going ?
Where are you located ?
Old 03-05-2010, 05:16 PM   #7
firehawkmph's Avatar
Rewards Points: 1,822
Lg,
Take a minute and update your profile with a location please.
I would rip a piece of 3/4" furniture grade plywood and attach a wood edging on the exposed ends with titebond III, it's waterproof. Use some low expansion window and door sealant foam between the windows and studs. Looks like you need some jamb extensions made up also. Kind of a goofy way to frame these windows in. I would probably use casing around the windows and also under the plywood shelf for an apron.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-05-2010, 07:21 PM   #8
Jay123's Avatar
The Following User Says Thank You to Jay123 For This Useful Post:
Scuba_Dave (03-06-2010)
Old 03-05-2010, 07:22 PM   #9
Jay123's Avatar
On the other window...well, let's just say it's not a quick-draw
Old 03-05-2010, 07:25 PM   #10
jay's got it
The older I get the better I was
Old 03-05-2010, 07:31 PM   #11
Jay123's Avatar
That's just mike's thoughts in an image...but I definitely agree and would do it the same way.
Old 03-05-2010, 07:54 PM   #12
Thank you very much Jay and everyone else for the great advise. I live in Vancouver, British Columbia, for those who asked my location.
Old 03-06-2010, 12:52 PM   #13
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Jay,
Quite cool how you illustrated Mike's thoughts. Your illustrations were great! (Very Professional) For most folks, visualizing based on written is difficult. Adding some visuals simplifies everything.
Anyway, nice job by you and Mike!
Kevin
Kevin M. is offline   Reply With Quote
Old 03-06-2010, 01:11 PM   #14
Jay123's Avatar
Thanks Kevin, I appreciate it. I do fairly detailed drawings for all of my projects, helps to make sure we're all talking about the same thing.
http://picasaweb.google.com/jjfwoodw...eat=directlink
Old 03-06-2010, 02:31 PM   #15
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Jay, Thanks for posting the Link to your album
You should be nominated to the DIY Hall of Fame
Scuba, You were almost there, Now you have to go a little farther.
Maybe it would help if you get super good, like Jay, on SketchUp.
Disclaimer
& Stay Safe
.....Bob Lavery
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
PVC window sills thegal59 Carpentry 9 09-20-2009 09:25 PM
Replacing Brick Window Sills gmac111 Building & Construction 3 06-12-2009 10:54 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Building A Window Box Rifeman Carpentry 4 10-28-2007 04:09 PM
