Building Soffit - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-18-2009, 10:03 PM   #16
Thanks Mike. What made you using 1x6 T&G pine instead of 2x4s? to save head space? Did you have any support in the middle?
xuc318 is offline   Reply With Quote
Old 12-19-2009, 09:35 AM   #17
sorry no pics to upload and not sure how to find one or draw one to show you, less than computer savy. I beleve a hardware store will have a threaded stud for attatching a standard nut and washer on one end and a lag on other end. This is a one piece bolt, hopefuly someone will read this post and be able to direct you a little better. I have used these in the pst but do not know a tech name for them
Old 12-19-2009, 11:10 AM   #18
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
You can use a hanger bolt and coupler attached to the threaded rod. If you ever plan to remove it, put lock nut or epoxy in the coupler.
http://www.boltdepot.com/dimension.a...&cs=180&cm=106
Kevin M. is offline   Reply With Quote
Old 12-19-2009, 12:48 PM   #19
thank you kevin exactly so
Old 12-19-2009, 01:41 PM   #20
Kevin M.'s Avatar
Rewards Points: 150
You're welcome
Old 12-19-2009, 08:33 PM   #21
firehawkmph's Avatar
Rewards Points: 1,858
XUC,
I just wanted to try something different and maintain as much headroom as I could. Plus the pine goes up easy and is fun to do. Stain before hanging. I used a couple pieces of lattice to make an outside corner on the bottom corners. Since doing these, I miter the corners of the pine so a small piece of outside corner will cover. The miters don't have to be tight, just reasonable close. Here's some pics.
Mike Hawkins
building soffit-img_4375.jpg   building soffit-img_4376.jpg   building soffit-img_4379.jpg   building soffit-img_4377.jpg
firehawkmph is offline   Reply With Quote
Old 12-20-2009, 04:26 PM   #22
Registered User
Rewards Points: 5,466
Very nice! Others may want to do some research first, as you probably did. At installation, maybe wrap the ducting with some suitable insulation or rigid foam to keep the heat in the supply trunk line, not exposing the wood. Watch the flammability ratings for such use. Otherwise, over time, the constant heat could dry the moisture content down to change the size of the individual boards causing open gaps at the t&g joints or splitting if they are securely nailed. Be sure to use a finish that is compatible with baking in an oven, on low heat, for extended periods of time. Or maybe just acclimating it for awhile to like wood flooring. It's amazing how much wood can move with humidity changes: http://www.woodfloorsonline.com/tech...oodwater1.html
I like the checkerboard floor!
Be safe, Gary
Old 12-20-2009, 06:09 PM   #23
Thanks Gary,
I took those pictures yesterday. As you can see, we are getting ready to have everyone over on Christmas day. That wood has been up for 6 years now with no noticable shrinkage. The black and white floor is ceramic and was supposed to be the bar area. Turned out to be the music room. My son and I would use it at different times for band practice.
Mike Hawkins
Old 12-20-2009, 08:18 PM   #24
Registered User
Be safe, Gary
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Building a soffit around a drainage pipe along the wall ssudha17 Building & Construction 12 10-04-2008 03:18 PM
building a soffit can I use 2 X 2s yummy mummy Building & Construction 13 11-14-2006 07:57 AM
