Building A Short Span Handrail - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 09:14 PM   #1
Lord of Slums
Rewards Points: 1,974
Building a short span handrail
I have not laid out the exact measurements yet. I have two handrail that will need to be at least three feet long. They will be spaced on each side of a door 38 inches apart. My biggest concern is mounting a 4x4 post onto concrete. How much side to side force can a 4x4 post 34 inches high withstand? Was going too mount the post with an outside collar. I am open to suggestion on how to mount the post into the concrete. The rail is on the inside of a garage. The top edge of the rail will be mounted into the wall. I want too surface mount the post on a 4 inch garage slab. Can not create a trip hazard
mj12 is offline   Reply With Quote
Old 07-06-2013, 09:48 PM   #2
Rewards Points: 12,802
Got a picture of where you want to build this?
A hand rail has to be able to withstand 200 lbs. of side pressure to pass code.
Old 07-06-2013, 10:14 PM   #3
Lord of Slums
Handrail on the right is to be removed, grip bar on the left is also to be removed. The stairs are staying. I am open to suggestions on this job. Want to stay in wood, metal is too expensive
Old 07-07-2013, 11:41 AM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
It looks you might be able to use the mounting screws from the rail that is already in place. I can't tell how it's mounted but you may be able to retro fit it somehow. Or, if the stairs are solid enough , and anchored to the concrete, you could attach your post to them.
Millertyme is offline   Reply With Quote
Old 07-07-2013, 08:50 PM   #5
Lord of Slums
Another thing, if I use 4x4 posts what type of wood should I use. I was going to use a light stain to finish, or leave bare. I was thinking popular. What type of wood should I use for the handrail itself, if I just go with a 2x 3 or something.
Running electrical to a out building J Bar L Electrical 6 09-19-2012 12:45 AM
Aluminum beam span for arbor btphelps Building & Construction 0 09-01-2012 04:45 AM
getting a building permit after construction is done ChrisJJ General DIY Discussions 22 08-15-2012 09:18 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
