Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-29-2009, 10:15 AM   #1
building shelf with questions..
just fyi i am far from handy when it comes to building things, so i attempted to build a shelf out of 3/4 wood and used a friends nail gun with 3 inch finishing nails the shelf is fine. I believe it to be a tad heavy but i am sure it will work but the self is 4 inches thick which is too thick for my eyes to bare. The shelf is going to be mounted to studs ( 3 to be exact) and will need to bare around 20 lbs and need to be about 36 inches long and 13 inches deep to hold my cable box and blu ray player. I am going to take another stab at this and try to frame shelf out of 2x2 and skin it with 1/4 wood that looks nice so i wont have to stain it and use 2x2 for the Bracket/wall support.(floating shelf)
any ideas or input before i attempt to build this?
typo is offline   Reply With Quote
Old 12-29-2009, 05:16 PM   #2
I don't know why you built it that thick. A simple 3/4" shelf would carry the items you listed.
You don't mention the supports you're using. If it's simple brackets, you're over building. If you want a decorative edge, you can simply add molding, in whatever thickness appeals to you.
Ron
Old 12-29-2009, 06:50 PM   #3
Yeah, just get a 1x12 and screw your brackets to the joists.
pyper is offline   Reply With Quote
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
A few questions about building a wooden privacy fence in Florida Tineras Building & Construction 4 03-22-2009 02:38 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 05:36 PM
Handrail building code questions - Canada Peterpantz Carpentry 7 10-26-2008 01:24 PM
