Building A Shelf In Basement Renovation. Need Help - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 05:32 PM   #1
Building a shelf in basement renovation. Need help
Hey everyone, new to this forum . I am trying to build a shelf for my wife in the basement but am stuck at what to do from here ( see attached picture ). I was thinking maybe some plywood behind the wood shelves and then Sheetrock behind it going down ? I appreciate everyone's responses in advance.
Thanks !
Jp
http://i1299.photobucket.com/albums/...ps312ced80.jpg
Jperrotta is offline   Reply With Quote
Old 12-23-2012, 05:55 PM   #2
Is the shelf going to sit inside the wall?
Develin is offline   Reply With Quote
Old 12-23-2012, 06:20 PM   #3
Yes. It will be going inside the wall.
Old 12-24-2012, 06:10 AM   #4
Is that some sort of water/heating system there? Are you sure you want to box it in? Is anything likely to need maintenance?
Old 12-24-2012, 10:29 AM   #5
Rewards Points: 12,790
#1 The underside of those stairs was suppost to have 5/8 fire rock to meet code.
#2 Looks like you may trying to build a wall without a pressure treated bottom plate. (can not really tell about the whole wall because picture was take to close up)
#3 Really should have built a wall first on the side of those steps so your not just looking into the area where the heater is as you come down the steps.
#4 That storage area is going to need a door with louver for supply air for the heater, or at least a vent in the wall.
If I had to build what your trying to do I would have framed it as if I was building a closit, sheetrock it then do one of two things, build a shelving unit and slide it into the space or just add some shelving.
If it was mine I would frame the opening so a standard sized bifolding door would fit.
Jperrotta (12-24-2012)
Old 12-24-2012, 11:40 AM   #6
Yeah I am building a wall on the inside of the stairs before I finish this.
The bottom floor plate is all pressure treated lumber. The reason you don't see it because the picture is up close.
There are two 24" bifold doors down the wall in the middle to reach the hot water heater and condenser. I also have built the wall a few feet off the cement wall to allow access to the electrical panel.
Yeah I am just trying to get a handle on this as my wife is driving me crazy as I originally wanted to at an angle place Sheetrock and seal that part off
Thanks again
Jp
Old 12-24-2012, 12:37 PM   #7
DIY staff
Rewards Points: 7,174
Simple,handsome cabinet style shelves can be made up like open boxes---use cabinet ply if you wish to stain them---slide lem into the openings and nail them in---Trim after the drywall is in---
Basement Renovation - (Old) Foundation Question Tummon Building & Construction 3 11-07-2012 10:56 AM
Building a fireplace mantel shelf NewHomeDIYGuy Carpentry 2 08-20-2012 04:22 PM
Thoughts around basement renovation quote NeriN. Building & Construction 4 03-26-2011 11:45 PM
Building mud room in the basement. DIY Hack Project Showcase 0 01-20-2010 09:48 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
