Building Screen Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-19-2010, 12:58 PM   #1
Rewards Points: 730
I have an odd size opening for my 2nd floor deck door so instead of paying hundreds for a DYI kit, I'm building my door from scratch. I ordered 2x6 douglas fir stock from the local lumber yard and I'll rip it down for my needs, but I have a few questions....
1) What is going to be my strongest/best option for the joint between rails and styles? I have a biscuit cutter attachment for my router. I have a pocket screw jig. ....and I could cut a motise and tenon joint with my router. The door will be painted, so I can plug and hide the pocket screws. This sounds the easiest, but will it hold up outside? Everything would be glued as well.
2) Since the lumber will be 1-1/2" thick, I'll have to plain it down to size. I've noticed most of the better doors are 1-1/8" thick. Is that the thickness I should go with or should I maybe go with 1-1/4"? I'm guessing 1-1/2" would be too thick, but maybe not.
Thanks for any input.
Master Brian is offline   Reply With Quote
Old 08-20-2010, 09:17 PM   #2
just to confirm: you're building just a screen door and not a regular solid door, right?
i wouldn't hesitate to recommend the mortise and tenon joint for rails/stiles.
for just a screen door maybe you could get away with pocket screws and butt joints.
all the screen doors i've ever seen are always so dinky and lightweight that, even installed correctly, they quickly settle/warp/twist, etc... such as to not properly open/close anymore. partly it's probably the cheesy cope/stick joints and finger jointed wood.
but my point is, don't intentionally make your stock thinner, unless you need to do it for the opening's sake.
i would glue the mortise and tenon, and also reinfornce with either dowels or screws.
good luck.
wombosi is offline   Reply With Quote
Old 08-21-2010, 11:25 AM   #3
Rewards Points: 730
It is just a screen for a rarely used deck off my 2nd floor. I plan on doing 1-1/4" for the thickness with 2" stiles and 5-1/4" rails. At this point I'm leaning towards mortise and tenon joints and probably will dowel them as well. I agree everyone I've seen looks like crap after a year or two....hopefully, I can build myself a better one!
replacing screen material on storm door gquayle General DIY Discussions 2 01-25-2010 07:26 PM
Installing door into block building oldgoatz Building & Construction 6 10-08-2008 05:26 PM
Help hanging a problematic door Termite Carpentry 12 07-21-2008 07:05 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Patio Screen Door adjustment econdave Building & Construction 3 05-30-2006 01:17 PM
