Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-06-2010, 08:44 AM   #1
Building a queen size bed frame
I have a queen sized mattress and box spring that I want to use in an upstairs spare bedroom. Unfortunately with a narrow staircase I am unable to get the box spring upstairs. I did manage to get the main mattress upstairs because of it's flexibility. Windows are too small to haul the mattress through the upstairs windows. So what I'd like to do is build a queen sized bed frame that I can assemble upstairs and use slats to support the mattress.
I've searched online for some frame plans but haven't found anything I like. Any of you guys have schematics for a queen sized bed frame that's relatively easy to make. I don't need anything fancy or ornate.
speedster1 is offline   Reply With Quote
Old 07-06-2010, 08:06 PM   #2
All you need is the hardware to hang the side rails. You can do a web search for that. The side slats get a cleat attached to the bottom for the plywood to sit on. Put a few mid supports to the floor midway, side to side.
The frame should be about 1" wider and longer then the mattress.
Plans should be available online for a bed frame.
Ron
Old 07-06-2010, 10:09 PM   #3
It was a dark and stormy
Yoyizit's Avatar
With no center support rail or post, use hardwood slats, 1x3 or 1x4, as many as you need to get the stiffness you need.
Copy IKEA's designs.
Old 12-28-2011, 05:05 AM   #4
Sofa Bed Mattaresses
sofabed's Avatar
I think going for the customized frame was really good, and you'd have created a frame for the mattress. I just want to know how I can create a frame which can be used for keeping the items as well, underneath the mattress. I want to have a cabin type bed for my bedroom, but not getting the kind of bed I want. So, I'm thinking of getting one sofa bed mattress, and then go for a customized frame.
sofabed is offline   Reply With Quote
Advice on building a backyard studio/office? johnnyb10 Building & Construction 11 12-04-2011 12:43 AM
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 09:26 AM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 03:23 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
