Building Platform Bed Frame - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-10-2014, 04:35 PM   #1
Rewards Points: 422
Building platform bed frame
I need to build a simple full size, platform bed frame. It also needs to have a lip around the perimeter so the mattress doesn't move around.
1) Should I use 2 X 4 or 2 X 6 pine for the frame?
2) How much larger than the mattress size(don't have it yet) should I make the inside dimension of the frame?
Thanks.
Jim McC is offline   Reply With Quote
Old 02-10-2014, 04:43 PM   #2
Rewards Points: 13,750
Just Google platform bed frame plans dozens come up.
Some even tell even have cutting plans and places to buy the hardware.
2 X 4 will not work.
Old 02-12-2014, 01:06 PM   #3
Rewards Points: 422
Thanks Joe. 2 x 4's are not strong enough? Even if the span is the short way, 54" ? It's for 1 adult, 160 pounds.
Old 02-13-2014, 10:02 PM   #4
Rewards Points: 422
Thanks Joe. Is OSB a bad choice for the bed's platform, health wise? What's an inexpensive option? (Will not be seen under mattress).
Old 02-16-2014, 10:26 PM   #5
r0ckstarr's Avatar
Rewards Points: 2,052
Why wouldn't 2x4's work? Just curious.
r0ckstarr is offline   Reply With Quote
Old 02-17-2014, 09:20 AM   #6
http://www.freeww.com/platformbeds.html
Old 02-17-2014, 09:38 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Pine is a poor choice for exposed wood in that it's soft and prone to splinters. You can get clear pine but it will cost as much as most hardwoods.
You 'could' use 2x4's but it would be heavy and ugly.
OSB will outgas and will be rough on any type of cloth. Paint grade plywood would be a better choice.
The Following User Says Thank You to ddawg16 For This Useful Post:
r0ckstarr (02-17-2014)
Old 02-17-2014, 09:43 AM   #8
A 1" (horiz) x 6" (vertical) is very strong.
Mobile Home Platform frame subfloor SchoolDaGeek Building & Construction 3 09-23-2011 08:36 AM
Building a frame for a slimline shower tray Johnson786 Plumbing 2 02-10-2011 02:15 PM
Building a storage building / small shop..please step in. J S Machine Building & Construction 35 01-20-2010 12:54 PM
Building frame for painter's canvas Klawman Carpentry 3 01-19-2010 09:25 PM
Finding a suitable flooring material for Wood frame Condo building lsgko Flooring 1 02-20-2009 02:38 AM
