Building Kitchen Cabinetry - With A Twist! - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-20-2010, 08:39 AM   #1
Punk
TuscolaMatt's Avatar
Rewards Points: 85
Building Kitchen Cabinetry - with a twist!
My kitchen sits in the corner of the living room - it's all one big room. I recently finished (mostly) the rebuild of the living room, and have now started on the cabinets. My brother does custom cabinetry for a living, so I've picked his brain a little and jumped into building a new kitchen from the ground up. Anyway, I want MY stuff do be different (and maybe even original!) in design. After looking at hundreds of other designs, I came up with something I haven't seen - I'm going to offset all the drawers from the cabinets so everything 'interlocks' in a unique way.
Here's the living room before:
current:
My conceptualization for the cabinet design (in general):
You can see that the drawers are centered differently over the doors. Since these will have granite (heavy) tops, I will be simply building separate cabinet and drawer boxes - this will make it the strongest (but will use a lot more material). This way I can easily create the offset though. Once all the boxes are built (birch plywood) then I'll build the oak facing for it all (can't wait for that part!).
One of the cabinet boxes:
it'll be all Kreg Jigged together. Inelegant but makes for fast assembly and will be plenty strong (not to mention not visible except inside the cabinets).
I've recently started on a 36" disc (39" cabinet) lazy susan:
this thing is a monster!
I'll be posting more as I go!
Visit the PARTYBARN!
TuscolaMatt is offline   Reply With Quote
Old 04-20-2010, 08:49 AM   #2
Old School
Willie T's Avatar
You are aware that the tops of the doors will get dinged up on any open drawers they hit? Only takes once or twice to ruin your work.
Willie T
Old 04-20-2010, 09:25 AM   #3
Punk
Rewards Points: 85
Yeah, my brother said I would have "interference" issues going this route and could result in a nasty 'wedge' situation. I chewed on that for a while. I kicked around ideas for the drawers to auto-lock when a door is open, but to set that up in reverse at the same time would be prohibitively difficult. So I will be doing two things: One - most of the doors will pull straight out on rails. I talked to my wife and told her it would reduce storage but would be novel as well as give easy access to the 'back' of the cabinets which often go unused anyway. She really liked this idea, so I'll go with it. Also, I plan on building a two or three extra doors/drawer faces and tuck them away. The upper cabinets will keep the same theme but won't have any conflicts (drawers) - so they'll hinge as normal... Anyway, there will be 8 lower 'doors' to deal with in this fashion and I very well may set them up to slide out 2 at a time (resulting in about a 28" "drawer" with shelves/racks in each for easier access). I will have a blind corner cabinet that I still haven't decided what to do with however. I can't do another lazy susan because of the way things will be set up...
Good catch btw! I've tried to think this all out but almost have to plan on snafu's since I loathe doing anything 'normal'. Thanks for the observation!
Old 04-20-2010, 09:59 PM   #4
Rewards Points: 262
It certainly is an original design and slide out bins will definately increase access to the back of the cabinets.
Jim F is offline   Reply With Quote
Old 04-28-2010, 12:03 AM   #5
What if, instead of hinging the doors, you made them true open-sided slide-outs? That way you would avoid the issue with doors running into open drawers and vice versa. The way I see it in my mind you would still be able to use the same layout you modeled.
Great project! Keep us updated.
**edit: Just re-read your post. Looks like you already thought of this! My bad!**
brich is offline   Reply With Quote
Old 04-28-2010, 07:53 AM   #6
Punk
Rewards Points: 85
Great minds think alike!
Since I take pictures of everything I do - I'll keep this going (for the next year at the rate I'm moving!)
Old 05-05-2010, 04:48 PM   #7
Punk
Rewards Points: 85
OK got some more stuff done.
Finished (for now) the lazy susan and set into place.
I don't have room in my shop for this stuff - so I'm storing it "in-place" as I go - I can also watch fitment this way AND my wife is able to see progress...
got the first kick base made (3" in 3" up)
test fit it here (also got the drawer boxes made and set in place)
next to the fridge will be the dishwasher and next to that - the sink
a fridge-sized pantry cabinet will go on the end here - THAT is going to be FUN to build!
I have 10 drawer slider-rail sets coming in for the drawers and to see if they will work for the cabinets too. I plan on the pantry having some nifty sliding and swinging parts in it as soon as I figure out what all I want and what to incorporate in...
I plan on completing the base cabinets (faces and drawers/doors) and get them measured for granite tops - then get them ordered. I'll work on the upper cabinets after that. I know I know that installing the upper cabinets would be WAY easier to do first - but we are functioning with NO kitchen right now and time is of the essence. Having a functional bottom is top priority right now...
Old 11-03-2010, 01:00 PM   #8
Punk
Rewards Points: 85
OK, I haven't updated this in a while - so here's where I'm at!
After my last post, I built the sink/dishwasher cabinet. I leveled/attached the bases. Next I built the drawer boxes and drawers.
...built one of the faces:
Made some drawer faces:
Put it together:
Next, had granite tops installed + sink:
(10 image limit reached! - next post!)
Old 11-03-2010, 01:01 PM   #9
Punk
Rewards Points: 85
now...back to the cabinets...made a prototype base drawer and face:
It's all shaping up to look the way I imagined - spiffy!
The way the cabinets slide open actually works well (I was worried!). Having two sets of sliders will give each cabinet a 200lb capacity - should be nice and sturdy. There will be glass installed on each (being cut as I speak). I will be painting the back side of the glass black to match the appliances and sink. I think the glossy aspect of the glass will be cool. After I polyurethane the faces - It's gonna look really great - can't wait!
I've got the new sink fully functional (+ Kohler faucet / soap dispenser) - waiting on the dishwasher to come in - I've got the plumbing ready to hook up too.
Next will be to finish the rest of the lower cabinets...
Old 11-03-2010, 01:20 PM   #10
Rewards Points: 150
Looks like its coming along real well! I like it, very different.
240sx4u is offline   Reply With Quote
Old 11-03-2010, 01:36 PM   #11
Interesting concept. Not sure I like it particularly but that means nothing. Congratulation on some original thinking. Are you going to mount a second cabinet drawer above the lower one? Seems like kind of wasted space if not. Wouldn't have to be attached to the door front but could be made to slide out seperately after the door was open.
Mike in Arkansas is offline   Reply With Quote
Old 11-03-2010, 01:48 PM   #12
Punk
Rewards Points: 85
I'll probably have some kind of box that will attach on the top of the slider box so the entire volume will be used - I just haven't thought that far ahead yet
My first goal is to just get these suckers built and sliding nice and smooth...
I'll decide what to do with the space after that!
Old 11-03-2010, 08:24 PM   #13
Leave the bottom drawers open on top and close the side like a regular drawer and you won't have to bend over to see whats in it. Easier to get stuff in and out. You could have one deep drawer attached to the door and two or more shallower drawers above without faces but with a nice handhold in the front. I'd use hardwood for the drawer front/sides and use dovetails or box joints exposed on the front, but that's just me. I put all drawers in my last kitchen (except under the sink and a special cabinet with a spring loaded shelf for my Kitcheaid mixer.) Having all drawers worked out really well.
Old 11-03-2010, 08:33 PM   #14
Punk
Rewards Points: 85
hmmm, I'll have to chew on some variations perhaps. Thanks for the ideas.
Old 11-03-2010, 08:45 PM   #15
Not my taste but I would say the craftsmanship is great and if you like it, that is the most important thing. I say nice job, I am jealous that I am not capable of doing that !
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Building a temporary workshop inside of large pole building HandyDave Building & Construction 0 02-17-2010 09:39 PM
Building a storage building / small shop..please step in. J S Machine Building & Construction 35 01-20-2010 01:54 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 09:28 AM
Kitchen island help Bob Sacamano Kitchen & Bath Remodeling 3 12-16-2008 06:38 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
