Building Double Doors? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 03:07 PM   #1
Rewards Points: 150
Building double doors?
I am wondering to guys have idea's on build double doors for a shed, the reason I am asking is because I would like to be able rip full sheets of plywood on my 10'' Unisaw. I would like the hinges be on the inside like and entry door and it has a door knob on it.
CJIII is offline   Reply With Quote
Old 01-26-2012, 04:14 PM   #2
Retired carpenter
You mean you want those wide doors on your shed so you have the room to cut the plywood? That sounds like a big project for something you might not need very often. Why don't you just take the saw outside or cut the plywood with a skilsaw?
abracaboom is offline   Reply With Quote
Old 01-26-2012, 04:52 PM   #3
Rewards Points: 150
It might not be good idea. I was talking about ripping plywood for built-ins and things of that nature.
Old 01-26-2012, 04:53 PM   #4
Rewards Points: 150
My shed is only a 10x12.
Old 01-26-2012, 05:26 PM   #5
Rewards Points: 2,202
If I understand right you will have to start outside and go through the double doors with your plywood.
What I do is use a 8' homemade saw guide somethng like this, even use sacrficial 2x4 and set saw to just cut through plywood. Then when have I have smaller pieces I use the tablesaw.
mae-ling is offline   Reply With Quote
Old 01-26-2012, 05:29 PM   #6
You can make door out of plywood and 2x4 on the flat around the edge. Get heavy duty door hinges, 3 on each side. If you want it not to warp use good straight grain lumber fir or something not regular SPF 2x4.
You could also get 2 36" exterior doors, insulated or solid wood and make a double door out of them. Depends how nice the shed is and what you want to spend.
Old 01-26-2012, 05:46 PM   #7
Rewards Points: 150
ok! The shed need fixing first.
Old 01-26-2012, 07:56 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
CJ, you have a unisaw in your shed? Man, I thought I was crowded with my unisaw in my shop.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-26-2012, 09:54 PM   #9
Rewards Points: 150
Yes I do, I need to put it on a mobile base.
Old 01-26-2012, 10:41 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
I plan on doing that also.
Jim
Old 01-26-2012, 10:44 PM   #11
Rewards Points: 150
What do you build?
Old 01-26-2012, 10:47 PM   #12
Rewards Points: 12,840
If a sheet of plywood is 8' long your not going to be cutting a whole sheet inside that building. You need a bigger shed or garage to do that kind of cutting.
Old 01-26-2012, 11:05 PM   #13
or a panel saw or a saw guide and circular saw
Old 01-27-2012, 04:47 PM   #14
Mold!! Let's kill it!
Rewards Points: 2,012
Yes. You can build doors. One of the quickest ways is to make frames out of 1x6s to the size you need and laminate sheets of 1/2" exterior plywood to each side of them. Use waterproof glue and clamp the heck out of them. Make sure you keep them well painted and they'll last for a long time.
Old 01-27-2012, 05:21 PM   #15
Rewards Points: 150
I was thinking about using 2x4's for the frame and 1/2'' CDX plywood for the middle.
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
Double Prehung Doors Oswald Carpentry 7 08-10-2009 07:43 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
