Building A Desk. - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 10:11 AM   #1
Building a desk.
I am in the process of building a 10' desk for my office. I used three ten foot 2"x10"s for the desk top. After installing the desk to brackets on the wall I have realized that the front board is significantly warped upwards. About 3/4 of a inch over the length of the board so the front edge of my desk on the right side is 3/4 of an inch higher than the back edge. Do you have any ideas on how I could pull that front edge down to be more inline with the rest of my desk? My thought is to use angle iron to try to pull it down.
ambrosierj is offline   Reply With Quote
Old 05-29-2012, 09:45 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
you used 2x10's as in framing lumber?
If so this would not be a suitable top for a desk. you want to use something flat and something that will stay flat for a long time. Like plywood or solid wood that has been edge glued for width.
Millertyme is offline   Reply With Quote
Old 06-02-2012, 01:21 PM   #3
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
Maybe you could mount your vice at this end................Oh sorry.....this is a desk right?...........mmmmmmmm :o)
I think you will be fighting a losing battle with those 2x10's. Probably the most economical way would be start again and use two Masonite 3080 interior doors.
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 06-04-2012, 09:49 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
I recommend removing the warped 2x and replacing with a straight one, all of the work involved with trying to straighten a 2x10 can be put into a simple replacement. just use the warped one for another project. also, 1/4" plywood over your desk top will help smooth it all out.
hand drive is offline   Reply With Quote
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Staining a Desk Too Dark asliger Painting 1 08-25-2011 04:13 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
What is standard height for recessed light above a desk? andmmy Electrical 2 06-15-2009 07:21 PM
Building a Desk under stairs kelrock Carpentry 9 03-18-2008 08:24 AM
