Building A Deck, What Size 2bys Should I Use? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 10:05 AM   #1
Building a deck, what size 2bys should i use?
It's a l shape 28/13 by 20/8, I would like to use 2x8's but worry about the weight ? Should i use 2x10's , also shape around a above ground pool
douglas12144 is offline   Reply With Quote
Old 05-02-2013, 10:09 AM   #2
Roofmaster
Rewards Points: 2,210
Not nearly enough data. PM me your email and I will send you the deck building PDF I downloaded courtesy of one of the Gurus on this site, I think Gary B. Maybe he will post the link again though.
Old 05-02-2013, 11:03 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
don't know about gurus ...... LOL
here is the link to the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide." it is based upon the code requirements of the 2009 International Residential Code, which may or may not apply to you case. A check with your local building department will provide you with your code requirements.
Some local building departments have their own "guidelines" for deck construction. again a check with them will help you out greatly.
deck codes have come about because of deck failures which not only costs money, but often leads to serious injuries and even dead. I have read that deck failures are one of the leading causes of accidental death in the home.
You may want to edit your profile to include your location, town, state. many answers to questions you may have are based upon location.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Questions on building a deck off patio EClayton08 Building & Construction 12 05-28-2012 04:02 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
Deck Boards and Deck Size Earnie Building & Construction 6 09-12-2011 08:38 PM
Building a deck - another project for later this summer (Question re: materials) DyerWolf Carpentry 8 05-07-2009 01:41 PM
