Building A Deck Over Patio - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 07:12 PM   #1
Building a deck over patio
I am building a deck over a patio. The frost line here in St. louis is about 30-36". I only have about 13.5" fromthe top of the patio to the bottom of the back door to work with so I have to use 2x8's for the beams and 2x6's for joists. I'll have to put 4 posts over the slab. So my question is do i have to pour footings through holes cut out of the slab to the frost line? if so would it be easier to remove the slab? The slab is against the house.
rammart
rammart is offline   Reply With Quote
Old 03-13-2011, 07:42 PM   #2
Rewards Points: 5,336
rammart
I don't think it's ever appropriate to rest a structure on a slab.
Ron
Old 03-14-2011, 07:20 AM   #3
What Ron said. The slab will move with freeze/thaw cycles. You need footers for support, below the frost line.
Old 03-14-2011, 11:21 AM   #4
Thats what I was thinking. I just wanted to make sure I was doing the right thing. Thanks guys!
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Deck repair, oops replace, oops new patio door thread drtbk4ever Project Showcase 19 09-16-2009 10:20 PM
building a screened in area on deck - deck heaves in winter burnt. Building & Construction 1 06-15-2009 11:35 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
