Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-17-2007, 03:35 PM   #1
carpenter savant
Smile building concrete walls
I would like some imput on this. I am working on building my home with concrete and have set up the pour with forms that are 34 ft high. I have all the rebar tied in but I am afraid of blow outs. the wall panels are 1 inch thick. I have a idea to fill the inside of the structure with aggregate to keep the inner forms from blowing and using cable braces arcoss the structure to keep the aggregate from pushing the walls out. I have built up aggregate on the outside of the house to keep the concrete forms in place. My question is. do you think this will be enought to keep the forms in place when the concrete is poured..the walls are 1.5 feet thick and 34 ft high all around. also how do I get the outside concrete to look like a stone wall.
miller4000 is offline   Reply With Quote
More On This Topic
Rammed earth construction is said to be one of the oldest forms of building. Aggregates, which can include gravel, sand and clay, are pressed into place using panels (known as formwork) to create the walls for the home. Builders of stabilized rammed... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. The next step in the process was to have the slab poured in the base here and actually I have that as a term key job because it was about 20 yards of concrete and that is more then... Read More »
You can make interesting objects for your garden and walkways with concrete sculpture. Concrete is readily available and you can make all sorts of simple objects from it. The following directions show you how to sculpt a bas-relief concrete decoration. Read More »
No matter what type of driveway you have--concrete, asphalt or gravel--you are at risk for developing potholes. Potholes are caused by water penetrating the surface of the driveway. In the case of concrete and asphalt, the water builds up under the... Read More »
Prior to putting in our 4x4 posts for our picket fence I put in about 4 or 5 inches of water at the bottom of the hole. I then will take about 1/3 of our first sack of our ready to mix concrete. I will pour just enough in there so that we can start... Read More »
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 17 07-25-2008 06:59 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 11:38 AM
Building walls around a furnace amazinlittledevil HVAC 19 07-31-2007 05:01 PM
Concrete walls on wooden joists stonehanger Building & Construction 3 11-24-2006 06:26 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 06:13 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
