Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-04-2009, 03:13 PM   #1
Question
Building code for Bedroom Doors
I found a beautiful door that I would like to use for my 2 bedroom doors! It is not a typical size, 84Hx28W. Is there building code that states your Bedroom doors have to be a certain size? I am located in Chicago if that matters.
nik2009 is offline   Reply With Quote
Old 05-04-2009, 04:16 PM   #2
Moderator
Check with your local Building Department. You may get 10 different answers here, but when you go to sell, you may have to change it.
Normal construction for bedrooms is 2'6" or 30" wide.
Usually a narrower door is to a bathroom or utility closet, linen closet, etc.
Make sure it meets your local egress (escape) code, as that is your primary escape route. Be safe, G
Old 05-04-2009, 08:02 PM   #3
you need to check your local codes as stated but I would bet my wife its to small for a bedroom not wide enough
clasact is offline   Reply With Quote
Old 05-04-2009, 08:22 PM   #4
Xtreme DIY'r
Only thing I have seen specified is 6' 8" high, nothing on width
But I wouldn't put in any door smaller then 30"
My last house had a 24" bedroom door, made the room un-useable - could not get most furniture in or out
I prefer 32" doors & 36" doors for all exterior doors
Building Code Laws phospher Building & Construction 45 03-25-2009 07:58 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 05:47 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
French Doors - Locking Dummy Levers highflyguy Building & Construction 4 10-08-2007 11:35 AM
