Building Cabinets Over Heat Pipes - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 01:34 PM   #1
WaldenL's Avatar
Rewards Points: 268
Question
Building Cabinets over heat pipes
We have a narrow (56") "room" that we want to put cabinets at the end of. This room is supplied with baseboard heat by a set of pipes running along the far wall, where we want the cabinets. Can I build a cabinet (floor to ceiling) over those pipe. I'd wrap the pipes in pipe insulation. the pic below is a side view of the cabinet wall, the pipe would be along the back bottom of the entire cabinet run. Doable?
WaldenL is offline   Reply With Quote
Old 01-25-2009, 02:49 PM   #2
yep
a little air flow wouldnt hurt though
II Weeks is offline   Reply With Quote
Old 01-26-2009, 03:10 PM   #3
WaldenL's Avatar
Rewards Points: 268
Any suggestions on how to add that air flow? I don't want to vent the pipe into the cabinet. Perhaps lifting the cabinet up off the floor by six inches (a six-inch toe kick?) and venting that space would suffice?
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Metal Building Heat buzzurd HVAC 20 10-19-2008 01:50 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Heat Tape on Pipes and Pressure Pump msully8548 Electrical 4 08-28-2008 12:33 AM
