Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-09-2009, 09:51 PM   #1
Default Building a cabinet ... a weird one...
Hello, I could really use some advice.
I have to construct a cabinet that will conceal plumbing and a water heater.
Basically it can have no back and no floor.
I have most of the framing completed. I joined 2, 1x3's together (glue, nail gun, clamped and sanded) for the stud pieces.
The wall piece is lag screwed into the studs and all the other pieces are bracketed together.
I also used threaded inserts and stainless lag bolts to level the front leg and 4 along the front bottom.
This cabinet is a little shy of 4 feet all together. 35 inches will have to support a concrete counter. So it has to be strong.
I have 3/4 inch plywood (birch) to use on the exposed side and over the top to add further support for the counter.
My question is will this be strong enough to support a 35x25 inch concrete counter, 1.5 inches thick?
My second question is do I need to have a center support?
I have pictures below and the last one shows a 1x2 as a center support. Would a 1x2 be enough?
Cabinet framed. Will have 3/4 side and top.
Do I need this middle support?
Thanks for pondering this with me. It is my first cabinet project and I want to do it as well as I can.
drillbit is offline   Reply With Quote
Old 07-09-2009, 10:33 PM   #2
Learning by Doing
Leah Frances's Avatar
What's your plan for accessing the water heater once the cabinet is built?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-09-2009, 10:38 PM   #3
Remodeler
MinConst's Avatar
Ditto, I'd add the 2 support legs but then you ain't gonna get the heater out. I wouldn't span more than 16" with that load.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 07-09-2009, 11:17 PM   #4
I was planning on installng some cabinet doors. Out of the 3/4" plywood.
My plan was to have the doors be flush with the frame. Put some stops to prevent overclosing.
The left side is also attached to the wall stud. The rear right, and the top back.
That is the thing. It needs to be accessable. One day that water heater will need to be replaced. Yet the center is where all that water heater stuff happens. The cut off, the drain valve. A board right there is just in the way.
The bottom piece is removable for that reason.
I can't go closer to the brick because of other issues.
I guess I could go with a lighter counter?
A concrete counter would weight roughly 120-150 lbs.
Old 07-09-2009, 11:25 PM   #5
Learning by Doing
Last April our hot water heater had catastrophic failure - it spilled gallons and gallons of water before we discovered the problem and shut off the water. Because of our experience, I would be reluctant to put any barrier in front of a cutoff. Make sure your doors will open freely and will not be obstructed.
Plumbers? What does code say?
Old 07-09-2009, 11:38 PM   #6
That is how I feel too. So much so that I had the primary water cut off placed above the counter for easy access. My plumber told me it was required to have a seperate one going to the heater, although it is the same supply.
Old 07-09-2009, 11:49 PM   #7
Learning by Doing
Old 07-10-2009, 09:47 AM   #8
gravity always wins
All that pipe with elbows hooked to the relief valve is certainly not a good thing. should be just a straight pipe.
Old 07-12-2009, 12:15 PM   #9
I'm not sure why they did the drain pipe that way. I guess it is so that it drains outside and not into the pan (which will also drain outside).
I have been standing on the frame and it has not made any uncomfortable noises or moved. So if it can hold me in one area then I'm thinking a weight distributed counter will hold up.
I also plan to add one more stud piece from a ceiling stud to the counter frame and a couple more cross studs in the left corner. This should give it a little more strength.
Old 07-13-2009, 01:05 PM   #10
If you can stand on it, I would not worry about the weight of the counter top. In my state only the MAIN water shut off valve has to be seen. Doors on each side of the 2x center support would be the way to go. However, I would have used PT lumber on the concrete.
Mop in Hand is offline   Reply With Quote
Old 07-14-2009, 12:11 AM   #11
Thanks Mop,
I have added not 1 but 2 additional studs from ceiling supports down to the frame. Thus the early testing of the frame, by me standing on it to reach the ceiling.
I hear you about the pt lumber and I did consider it. My compromise was to lift the bottom via threaded inserts and stainless steel lags. That gives me a 1/4" + in case of damage. Also, the floor is not even so this was a solution. I remember opening cabinet doors and standing on the toe kick to reach.
I'm still working on it. I just discovered that one of my walls is over 1" off level so I'm like . Of course this throws a wrench into my cabinet plans.
I paid that guy. He is long gone and I'm stuck with a crooked wall.
"If you want something done right, do it yourself." However, what if you have no idea what you are doing?
One board at a time.
Old 07-28-2009, 07:06 PM   #12
Okay,
Crooked wall is fixed.
Cabinet is covered with birch plywood sides and doors (as soon as I figure out how hinges work).
I can sit on it and I'm sure it would support a concrete counter. However, I have an opportunity to get custom thick gauge stainless steel counters with hat channels and a high profile edge for around 100 bucks more then the concrete attempt will cost.
I'm going with the stainless counter. It's too good of a deal.
I will post a pic when installed and doors hung.
I think it will look nice, weigh less, be removable should it need to be and offer the same properties that concrete would except that no sealing is required.
I'm going for industrial chic so hey, they are both gray.
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about buying lumber. Here I have two different types of lumber. This piece of lumber is treated and this piece of lumber is untreated. You know that it is treated because... Read More »
A patio storage space can come in handy for storing plant food, watering supplies, cooking materials, bug spray, barbecue equipment or even a handy deck of cards. Here's how to make one. Read More »
Hi! This is Diana for Expert Village.com and we are prepping our room now so that we can steam clean the carpet and I like to clean the ceiling and the window sills before I clean the carpet because once your carpet is cleaned, you don’t want all... Read More »
Those dedicated to the sport of fishing are also dedicated to their lures, reels and other special equipment. Finding the right box to fit items collected over the years is not always easy. Make a fishing lure box that suits the kind of fishing you do... Read More »
This is Kevin for Expert Village. Part of this job is going to require texturing the ceiling. We have a texture coat here, It's a very thick coat and formulated especially for ceiling. This coat will be applied by using a roller actually a small nap... Read More »
building my own kitchen cabinet doors... Jeremy Hillary Boob, PhD Carpentry 6 05-06-2009 01:38 AM
temp heat to building under construction LanterDan General Discussion 0 01-05-2009 12:24 AM
Mounting a flat panel tv in a cabinet Sonicendeavor Carpentry 0 10-24-2008 11:16 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-16-2008 12:59 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 08:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
