Building A Bed Frame - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 01:36 AM   #1
Rewards Points: 77
Building a bed frame
Would a 15 ga nail be enough holding power to build a bed frame?
Justins1171 is offline   Reply With Quote
Old 12-03-2011, 06:43 AM   #2
DIY staff
Rewards Points: 7,174
Not really----For an item of furniture --especially a bed---glue and clamps will give you the longest life and least failure---
Modern wood glue is stronger the the wood that it joins---no other fasteners should be needed--
A bed should be able to be disassembled for moving--so some thought should go into that in the design.
If you have a design idea or a picture of something similar to what you want---post a picture and someone here will offer a suggestion or two--- Mike--
Willie T (12-03-2011)
Old 12-03-2011, 08:27 AM   #3
Rewards Points: 5,336
Only a doll house bed frame.
Ron
B. Franklin 1759
Old 12-03-2011, 08:49 AM   #4
Rewards Points: 13,450
15 gauge is a trim nail size.
I've never once used nails of any kind when building any type of funiture. Glue, and screws using my Kreg tool to predrill the holes at an angle.
Old 12-06-2011, 07:31 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
no way man, Like posted above, they are usually made to disassemble. Rockler sells hardware kits that you will need to fabricate bed frames. They are priced reasonably there but you can probably get them cheaper elsewere on the net
Millertyme is offline   Reply With Quote
plans for building hot tub frame ilabar Building & Construction 1 08-16-2011 07:37 PM
Building a temporary workshop inside of large pole building HandyDave Building & Construction 0 02-17-2010 08:39 PM
Building a storage building / small shop..please step in. J S Machine Building & Construction 35 01-20-2010 12:54 PM
Building frame for painter's canvas Klawman Carpentry 3 01-19-2010 09:25 PM
Finding a suitable flooring material for Wood frame Condo building lsgko Flooring 1 02-20-2009 02:38 AM
