Building A Bed - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 07:17 AM   #1
Building a bed
Hello all,
I am planning to build a bed, I know all the sizes of materials I need and the costs and everything. However, I have run into a problem. How do I join the legs to the side rails in a strong manner? I thought I would use furniture bolts which are 125mm long, but I am concerned about drilling that deep. Most likely I will not be able to keep the drill straight and end up coming out from the side of the timber.
Any suggestions on how to make strong joints when connecting the legs to the side rails?
mashcaster is offline   Reply With Quote
Old 09-08-2009, 05:18 PM   #2
Registered User
Termite's Avatar
Use bedrail fasteners. They're rock solid and allow the bed to be easily disassembled and assembled with a rubber mallet. They make an incredibly tight connection with absolutely no wiggle. I've made several beds using these and swear by them.
http://www.rockler.com/product.cfm?p...ail%20hardware
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 01:19 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 05:47 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
