Building Barn Sashes - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 12:53 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
I want to close off my front entryway portico. This is unconditioned space so I thought barn sashes would be adequate. I went to my local lumberyard to price barn sashes. I figured since it's one pain of glass it would be relatively inexpensive; wrong. It's actually relatively expensive. The total for all the glass panels would come in around $1400 for a portico that's 3'x 8'.
Anyway, I don't have money but I'm fairly confident in my skills and have all the tools needed to build these sashes, so I think I'm taking that route. I'm thinking cape code style, so all square cuts.
So the first questions of many likely to follow is:
What species of wood should I use for sashes that will be painted on all sides?
Anyone know of a good online resource for instructions?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-17-2011, 01:47 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Cypress, Spanish Cedar, Redwood, Western Cedar, Mahogany and others. Do you have any pictures or drawings of the sashes?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-17-2011, 01:58 PM   #3
DIY staff
Rewards Points: 7,174
Also--do you have a table saw and a router table?
Old 12-17-2011, 02:06 PM   #4
I have gas!
Thanks,
I don't have any pics of what I want to build but simple divided light. The largest RO is on the sides (about 27x80). The front will contain a storm door, surrounded by sidelights and transom. The sizes are still flexible at this point as the openings are not framed yet.
I have all the tools I'd need: router, router table, SCMS, and table saw.
Old 12-17-2011, 02:19 PM   #5
DIY staff
I'll let Ole Jim help you----I'm not up to speed on exterior sashes----
Old 12-17-2011, 06:26 PM   #6
I have gas!
I found an old finehomebuilding pdf that shows a decent anatomy of a sash. Since I want to keep it simple (without any molded edges) it should be fairly straight forward. A drill press, which I also have, will make the mortises easier.
Alright, next week I'm off to the lumberyard to see what I can get for a decent price from the above wood species. Thanks again for the list.
Old 12-17-2011, 06:40 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
CC, there are several ways to build the sashes, the easiest is to buy the router bit sets made for windows.
http://www.amazon.com/55-801-Shank-W...5707642&sr=1-3
http://www.amazon.com/s/qid=12457076...w%20sash%20bit
By looking at the configurations of these bits it is easy to see how it is done. You can also make the parts with a router table using several different bits without buying the window cutter sets.
You can also make square sashes using a table saw or a slotting cutter, set up in your router table and a table saw.
The window sets are used somewhat like making cabinet door rails and stiles. I have actually made windows using a cabinet door set but there is a little more work to it.
Are you planning 6 over 9 or 9 over 9 or what?
Jim
Old 12-17-2011, 06:43 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
You must have posted as I was typing. Do you have a link to the site you found?
Jim
Old 12-17-2011, 06:52 PM   #9
I have gas!
I'm unsure what the light configuration is going to be. Now I'm thinking the big panels will be non-moving. That would simplify things greatly. I wasn't thinking of the window frame and the window weights (or some kind of counterweight) that would need to go into it.
Here's the link for the pdf. It's dated December 1983 but I can't imagine that there have been many advances in a simple barn sash since then.
Old 12-17-2011, 10:44 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
CC, that looks pretty straight forward, following that format and you will get it done. If we can help let us know.
Jim
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 02:09 PM
Need home plans for a simple barn home! RUMBLON General DIY Discussions 0 06-02-2011 03:05 PM
Building a basic pole barn fjacky Building & Construction 2 03-02-2010 09:58 PM
Building a temporary workshop inside of large pole building HandyDave Building & Construction 0 02-17-2010 08:39 PM
building a pole barn on a existing slab??? scott13676 Building & Construction 3 02-25-2008 06:29 PM
