Building A 60x40 Mirror Frame - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 10:16 AM   #1
Building a 60x40 mirror frame
Can it be done? Hubby says NO. (he is NOT a carpenter)
I'd like to re-hang a 60X40 bathroom mirror. You know..those BLAH contractor mirrors they slap up when ya have a house built. Its Ginormous and so ugly. I'd like to build a frame for it. Not around it..but I'd like to build a frame with the mirror inside it. Does it sound terribly ridiculous?
Thanks...
citygirl is offline   Reply With Quote
Old 02-27-2011, 10:34 AM   #2
Rewards Points: 558
Yes it can be done by making a rabbit in the wood frame to except the mirror and then drop the mirror in place and either add clips to hold the mirror in place or put a bead of clear silicone caulk on the back of the mirror to hold it in place.
epson is offline   Reply With Quote
Old 02-27-2011, 02:39 PM   #3
It's easier to build a frame over the existing mirror without removing it
mrgins is offline   Reply With Quote
Old 02-28-2011, 07:24 AM   #4
Rewards Points: 1,580
I agree with Mrgins; likely fairly heavy piece of glass. Don't forget to paint the side of the wood frame flat black to reduce reflection of the underside in the mirror.
bob22 is offline   Reply With Quote
Old 02-28-2011, 03:25 PM   #5
Cut the rabbet loose and caulk the gap between it and the face of the mirror. If you put it tight against the face of the mirror, the vibration of nailing it on will crack the mirror
getting a building permit after construction is done ChrisJJ General DIY Discussions 22 08-15-2012 08:18 AM
Advice on building a backyard studio/office? johnnyb10 Building & Construction 11 12-03-2011 11:43 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
