Building A 6' High 6' Wide Gate On Fence - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 07:37 PM   #1
liscenced electrician
Rewards Points: 538
building a 6' high 6' wide gate on fence
Im going to build a gate 6' wide on a 6' fence. Its a cedar fence. Does it need to be double doors? If so, how do i keep the double doors closing nicely together so they don't swing too far in?
jimmy21 is offline   Reply With Quote
Old 05-03-2010, 06:09 AM   #2
Double sounds better to me. Make them like French doors, with one anchored with a movable stop(pipe thru rail into ground or cement), and the other the active gate.
Old 05-03-2010, 12:34 PM   #3
Rewards Points: 538
that sounds pretty reasonable. Is that how most people do it? I measured it out again, and i don't think 6' is big enough. Whats the biggest you can make a gate door thats 6' high?
Old 05-03-2010, 02:15 PM   #4
kwikfishron's Avatar
Rewards Points: 814
That depends on how you build the gate, how heavy it is, what it’s hanging off of, type of hinges. You can go pretty big if you have a wheel on the bottom but wheels don't roll so well on gravel.
kwikfishron is online now   Reply With Quote
Old 05-03-2010, 04:00 PM   #5
Originally Posted by jimmy21 View Post
. . .gate door thats 6' high?
It's the width and weight that makes the top hinge want to pull out and the gate want to sag.
Old 05-03-2010, 04:01 PM   #6
Rewards Points: 538
i don't really want to put a wheel on it. I was planning on atatching to a 4x4 cemented into the ground. Would 5' wide gates need any special attention? I plan on building this really stout (but with weight in mind) to avoid any sagging
Old 05-03-2010, 05:37 PM   #7
Rewards Points: 1,016
Sagging gates and gate posts are a common problem. Having built many gates - unless this is a lightweight chain link gate I would make it two gates. Ensure the gate posts are very well secured in the ground.
labor cost for building a fence clintb44 Off Topic 4 08-18-2010 02:25 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 03:39 PM
Gate for wooden privacy fence RookVega Landscaping & Lawn Care 2 11-09-2008 09:56 AM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 02:36 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
