Build Secure Three Sided Partition - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-31-2008, 10:50 PM   #1
build secure three sided partition
I am looking to build a three sided partition wall that will not reach the ceiling in a commercial space using metal studs.Two sides will have viewing windows.One side an open doorway.What is the best way to ensure stability so there will be no movement of the walls?
kevinr is offline   Reply With Quote
Old 07-31-2008, 11:13 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
your going to have movement no matter what you try by the door openings. Thekctermite had the best way of securing a half wall in another post, by running the studs down into the floor cavity and fixing them to the floor joists or some blocking, but being its a commercial building i am thinking concrete floor. They do sell these office cubicles that you described. BOB
Old 08-01-2008, 10:46 AM   #3
Registered User
Termite's Avatar
Assuming you're dealing with a concrete floor, I would suggest having some steel brackets fabricated by a welder. They'd bolt to the floor, would be at least 3 or 4 feet tall, and would secure to the sides of the at the ends of the wall, and perhaps one or two in the middle of the wall. Otherwise, there's little chance of getting the wall stabilized unless the three sides of the partition have enough footprint to stabilize it as a unit.
Arcade Cabinet build from scratch in MDF and Plexi lokesen Project Showcase 20 10-05-2008 08:50 AM
Framing a partition wall on existing carpet and ceiling tile? eagle86 Building & Construction 3 07-23-2008 03:39 PM
I'm going to build a partition wall.. flyboylr45 Building & Construction 6 10-05-2007 09:56 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 04:39 PM
Cost to Build pallen Building & Construction 4 06-18-2006 11:43 PM
