Build Out Base Moulding - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 12:01 PM   #1
Rewards Points: 155
Build out base moulding
I have a few areas where the base moulding will not cover some of the gaps between the floor and the wall (yes I realize I probably could have a done a better job in some areas-but I did best I could)- In light of that- Is there way to "build-out" at least the bottom of the base moulding where it meets the floor and still lays relatively flush on top? Just figured I'd ask......just to cover a few small gaps
Huskyfan68 is offline   Reply With Quote
Old 12-04-2012, 12:40 PM   #2
Quarter round or shoe moulding
mterry is offline   Reply With Quote
The Following User Says Thank You to mterry For This Useful Post:
user1007 (12-04-2012)
Old 12-04-2012, 02:08 PM   #3
Rewards Points: 2,212
there are a variety of smaller moulding you could use depending on the desired result and the type of existing baseboard.
shoe moulding is the typical one. Also 1/4 round and even a flat 1/4" (or 3/8 or 1/2" wide by 1" high (or highe) used on the font of a baseboard.
mae-ling is offline   Reply With Quote
Old 12-04-2012, 02:45 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
either use quarter round or scribe the baseboard to fit the contour of the floor
woodworkbykirk is offline   Reply With Quote
Old 12-04-2012, 03:33 PM   #5
is it that the floor is uneven? (Hills and valleys) Then do as kirk states
Or is it that the baseboard won't cover the gap between wall and flooring. Then both work.
Old 12-04-2012, 04:55 PM   #6
Rewards Points: 512
yup quarter round or cove moulding. i personally like to use door stop trim that has close to the same profile of the baseboard. i find it gives it a much better look then quarter round.
princelake is offline   Reply With Quote
The Following 2 Users Say Thank You to princelake For This Useful Post:
mae-ling (12-04-2012), user1007 (12-04-2012)
base moulding identification bubbler Carpentry 1 08-13-2011 12:44 PM
Door Moulding Idea Help Vibber Carpentry 4 06-01-2010 07:51 AM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 10:52 PM
Patio Base dilema rwiltshire Landscaping & Lawn Care 2 07-12-2009 03:02 PM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 08:29 AM
