Build My Own Custom Interior Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-14-2013, 12:53 PM   #1
Rewards Points: 178
build my own custom interior door
The door opening in the basement office is not standard at 75 1/4" high and 34 1/4" wide. I'd like to build a door for it with a frosted plastic window (covering most of the area) and hang it on sliding door hardware. How can I simply build this door?
anuvanoob is online now   Reply With Quote
Old 10-14-2013, 06:34 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by anuvanoob View Post
I'd like to build a (75 1/4" high and 34 1/4" wide) door
How thick does it need to be?
How heavy can it be?
Rather than reinventing the wheel (or door)...
http://www.stanleyhardware.com/sub-c...ame-components
More Stuff Like That
Old 10-14-2013, 06:37 PM   #3
Rewards Points: 178
About an inch thick. Should be pretty light as I'm using hardware that's meant for a aluminum sliding door
Old 10-14-2013, 06:39 PM   #4
Rewards Points: 582
they make remodel doors to fit that opening......measure.. order.. install is a snap...ben sr see tarheels post for the link
Old 10-14-2013, 08:05 PM   #5
DIY staff
Rewards Points: 7,174
If you have a table saw, I can walk you through building a door. It might cost more than a store bought.--Mike---
ben's plumbing (10-15-2013)
Old 10-15-2013, 12:44 AM   #6
Rewards Points: 178
I only have a miter saw, skilsaw, reciprocating saw and multi tool. If possible I'd like to build this on the super cheap. If I could take the two 1/2" x 8' x 4' plywood boards, fasten them together, cut them to size and border them with firring strips and hang it on the track, I would simply do that, but I want the plastic window insert and I don't know have a clue how to do that.
Old 10-15-2013, 06:32 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
You may be able to find what you need on the shelf. Use select 1X4 boards instead of furring strips. They may be straight when you pick them out but they won't stay that way. Once you have your frame built you can use stop & window molding to set your panel.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-27-2013, 08:15 PM   #8
Rewards Points: 636
buy a 34 inch wide hollow core door (under $25 in my area) cut to height re infill bottom with solid wood. cut opening for window infill with solid wood use outside corner moulding to frame in the cut out to hide imperfections that are in your hole cut out. put window in with half round or glass stop (glazing bead) on both sides to hold in place.
in my area material cost for door and trim under $50
https://www.google.com/search?q=3%2F...lding&tbm=shop
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
Can I build new PC on top of gysum board instead of floor baby327nd Electrical 15 10-09-2011 04:44 PM
Custom wall tv unit laflsyl10 Carpentry 3 08-31-2011 03:20 PM
Build or buy a shed and costs? Piedmont Building & Construction 7 05-19-2009 08:13 PM
