Buckling Laminate Floor Due To Water Leakage. - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 07:22 PM   #1
Sid
Buckling Laminate floor due to water leakage.
Is it OK to install another laminate floor on top of one that is slightly buckled rather than removing the buckled floor?
All thoughts and theories welcomed
swilso5 is offline   Reply With Quote
Old 08-13-2011, 07:49 PM   #2
if its the click together laminate it would only take less than an hour just to lift it up if its just one room.
if its buckled will the new floor hump up over the buckled area. i would remove it but its your floor.
any chance of just replacing the buckled pieces?
Old 08-13-2011, 08:05 PM   #3
Rewards Points: 5,336
No, you cannot put another floor over the top of a buckled floor!
Ron
B. Franklin 1759
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
