Broken Wooden Step - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 09:04 PM   #1
hi iam new here, i just started to try and fix things around the house. I just stepted out the door and the bottom of the wooded step split in have leaving the other have under the door, how can i repair this, i just bought power tools etc, and this looks like my first fix any help will great. remmber i am just starting out
I steped out side my back door and it split in half leaving half under the door it's wood a step off i guess, it might even be part of the frame. Can someone help with some info. on how to repair it. i want to do myself it's the only way to learn.
thanks mountaint
mountaintony is offline   Reply With Quote
Old 09-07-2010, 08:29 AM   #2
A picture would help
To show what exactly broke
Old 09-07-2010, 08:47 AM   #3
Rewards Points: 120
As Dave said, a picture would definitely help, but in the mean time, it sounds like you might be referring to the threshold. If so, I would try to keep it intact as possible, as you may want to have the ends available for reference when you cut a new one to fit. Once you get it out, you should be able to get one at your local lumber yard. Again though, try to post a picture, as it is only a guess at this point.
Old 09-07-2010, 02:51 PM   #4
Sometimes a complete replacement is necessary sometimes some water proof glue and Miller Dowels will do the trick. You need to provide a little more info and as stated above pictures would be helpful.
hayewe farm is offline   Reply With Quote
Old 09-08-2010, 09:53 AM   #5
have pictures to show what broke off, any help would be great
Old 09-08-2010, 08:26 PM   #6
broken threshol
Old 09-08-2010, 08:32 PM   #7
Please stop starting new threads on this subject
You have started about 4 threads which have been merged into 1 thread
ADD on to the existing thread
Moderator
Old 09-09-2010, 01:45 PM   #8
Tizzer's Avatar
Rewards Points: 460
The piece that broke off, you still have it? If it wasn't rotten you could try some exterior grade glue & a couple finish nails.
Tizzer is offline   Reply With Quote
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-08-2009 11:02 PM
Step footing has gaps joshoc Building & Construction 4 05-06-2009 04:11 PM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 11:19 AM
Advicce on broken joint on wooden frame of chair markhod Carpentry 2 08-11-2007 08:48 PM
