Broken Screw In Composite Deck - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 08:54 PM   #1
Rewards Points: 107
Broken screw in composite deck
I was taking up a composite deck board over the weekend to examine a downspout. As I was backing out one of the deck screws with my drill driver, it snapped in half. SO, part of the screw is now in the deck. I don't want to dig in there because it is composite. What is the best way to get rid of it? Drill down over it?
Ranger1227 is offline   Reply With Quote
Old 05-24-2011, 10:37 PM   #2
would this work for you? i used to just take a small drill bit and drill holes all around the broken part til i could get the piece off and then get the screw with pliers
http://www.rockler.com/product.cfm?page=2354
Old 05-24-2011, 11:49 PM   #3
rock16's Avatar
Take the rest of the screws out of the damaged board.
Pry the board off the damaged screw taking care not to damage adjacent boards.
Now you can remove the screw or hit it with a hammer and it should break off flush.
re-install the board using the same holes.
rock16 is offline   Reply With Quote
Old 05-25-2011, 10:28 AM   #4
Rewards Points: 107
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
Evergrain composite deck - Kansas brandonriffel Project Showcase 0 06-15-2010 10:11 PM
Deck screw in drywall? Ininkus Building & Construction 4 03-24-2009 04:36 PM
New deck, nail or just screw it! steve f Building & Construction 3 05-15-2008 09:17 AM
composite versed plastic deck material winx40 General DIY Discussions 5 09-15-2007 08:14 AM
