Broken Drill Bit - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 02:07 PM   #1
Broken Drill Bit
HELP!
I was drilling pilot holes for chair glides in an Amish made dining chair and the drill bit broke off IN the chair leg. Nothing is protruding, so I cannot grab the shank with vice grips and back it out.
Anyone have any advice?
uthpastordave is offline   Reply With Quote
Old 07-19-2010, 02:08 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
needle nose pliers in the flutes of the bit. Turn it counter clockwise as you pull backwards.
Old 07-19-2010, 02:13 PM   #3
I'll give it a try... now... where are my needle-nose pliers? :D Hoping this works!
Old 07-19-2010, 02:14 PM   #4
Electrician
Proby's Avatar
If you can't get it out, can you drill a secondary hole to the side? Or can you attach the glide in another fashion (maybe glue this one)?
Proby is offline   Reply With Quote
Old 07-20-2010, 11:17 AM   #5
Rewards Points: 5,336
If you can't go next to this broken bit and need to remove it, they sell very small hole saw bits that will cut around the bit so you can remove it. You might need to insert a dowel to fill the hole if it's too deep for the glide.
I bought one from Rockler when I had a screw head snap off in a cabinet frame.
Ron
Old 07-20-2010, 11:57 AM   #6
gmhammes's Avatar
ahh, how many drill bits on forever in my projects! lol Most of the time it happens when i am counter sinking.
gmhammes is offline   Reply With Quote
Old 07-21-2010, 05:58 PM   #7
Rewards Points: 1,214
Ron
Sounds good I'll have to remember that.
COLDIRON is offline   Reply With Quote
Is my new hammer drill broken? darsunt Tools 13 09-16-2009 10:53 PM
broken drill bit ricemaiden Tiling, ceramics, marble 2 04-22-2009 10:29 AM
Help with broken drill serill Tools 2 09-08-2008 12:14 AM
Broken Drill Bit . . . chins01 Remodeling 4 01-25-2008 12:38 AM
Broken Drill Bit Freelancer General DIY Discussions 15 03-29-2007 05:01 PM
